led indicators
led indicators
Ive just bought some rear led indicator bulbs (error free) they work fine but it ticks fast as if a bulb has gone! Will they all do this or have I bought some duds? They cost £18
2010 space grey se dynamic pack and lots of toys
Re: led indicators
Think the load is too low and you need a resistor to help.
Re: led indicators
Shouldn't they have them as there error free?
Re: led indicators
Are your front ones still working ?
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
Re: led indicators
Error free they may be but as Sanj says, you will need a suitable resistor to slow it all down.
The error free part is so that the LCM doesn't see the LED's as a blown lamp, but if it doesn't see a high enough resistance it will cause the flash rate to be too fast.
Runabout - E92 3 Series Coupe
Re: led indicators
I understand now, I will look into it. Thanks guys.
Re: led indicators
Jay,
Just out of interest what type of fitment are the rear indicators as I plan on doing them also with my new LED rear lights.
Thanks!
James
Thanks!
James
Re: led indicators
the bulbs have slightly offset pins. The led ones I got wernt but I still got them to fit
hope this helps. Jay
Re: led indicators
That's great thanks for uploading! I was looking at those exact ones actually. Apart from flashing too fast
Are they pretty bright?
Re: led indicators
They aren't much brighter than the old ones but are so much sharper ,you get no bulb fade if you know what I mean.
Re: led indicators
Yeah I no what you mean LED's are so much faster at lighting up and go off instantly I like that look a lot.
