high voltage on OBD pin 7
Posted: Wed Nov 20, 2013 11:52 am
Hello
Coming out from lurking in the shadows again.
I am having troubles get my obd readers to work.
my bmw scanner stopped working and my C100 read some information but not the modules I need EHC...yes my air suspension is still playing up...sigh..i have elm module and all scanner work on other cars so it is my car with the issue.
I check the voltage of the pins using a multimeter and get 9+ volts on pin 7 ..K-line I believe which does not seem to be right. I have pulled all but the high volt fuses in glove box and read cabin but still cant find the fault.
I turned on everything an let the battery drained down until the volts where under 6 and I could read more modules....ehc still was quite working but I am convinced this is due to overvolatge on the line. My battery went dead for the first time a few weeks ago( I rearly drive the car) so I got an s5 and ctek charger
I know I have had my sat/nav reset itself and my main screen sometime reboot, I have seen an ac fault and my panoramic sunroof broke in the usual way(rear panel stayed up) I concentrated on all of those fuses especially however I have only been pulling fuses one at a time where as I know several system, radio,ehc..etc uses multiple fuses...I will try pulling multiple related fuses this weekend but I was just wondering if anybody had any ideas?
Thank in advance
Thank in advance
