Auxillary water pump causes cold running...who'd have thought
Posted: Wed Nov 20, 2013 10:10 pm
by storminmike
Well.... whilst on the Webasto journey the cold weathe revealed all was not well with the engine and cabin heating. The gauge NEVER got beyond the first tick after blue (1/3rd basically). If the car was forced to by spirited driving it could get just above that mark....but only just.
Back in April I had the thermostat replaced and was convinced that this had failed somehow. In desperation because I was cold, the engine ran less than optimal I took the car back to the indie. An error code check revealed "Auxillary water pump fail".....ehh :blink:
This was replaced (not a cheap part) and everything is toasty....wonderfull however illogical
One day I will maintain something instead of fixing dead bits :'(
New bit count
New rear wishbone arms rear plus bolts and bushes
Steering Arms (both bits) both sides
Climate module
Thermostat
Air filter
Oil and filter,,,,a few times
oil seperator
Webasto
Steering wheel panel
transfer box oil change
discs n pads front and rear
many tyres
new clear indicator sides
HID kit
Fix rear light bulb fail fault
hand painted gear knob wear fix....now shiny and glossy
painted rear bumper bottom trim to mimic is
still to fix
PDC tone front
weird wear on steering wheel
refurb alloys
chip fixes to bonnet
if only
blue tooth hands free complete with some music interface kit
another oil change perhaps
brake fluid change
fake exhaust tips
buy scanner software
Re: Auxillary water pump causes cold running...who'd have thought
Posted: Thu Nov 21, 2013 1:28 am
by nujon
You have been lucky!
Posted: Thu Nov 21, 2013 9:20 am
by Bargain Bucket
[quote="storminmike"]
still to fix
PDC tone front
I lived with that fault for 2 years. Took me £15 and 30 minutes to finally fix it. Why the heck didn't I do it sooner?
Posted: Thu Nov 21, 2013 2:30 pm
by Jayx5
Ive got a sensor to replace now cos the wife got in the car after a kids party turned the pdc off as the beeping was annoying her and reversed into a post! >:(scratching the bumper and popping out a sensor that fell off! You couldn't make it up!
Posted: Thu Nov 21, 2013 3:19 pm
by Bargain Bucket
Ahem - why do you think I finally fixed my sensor? Cost me another £150 in insurance premiums cos the other guy got a dodgy quote for £700+VAT to replace an Astra front grille. No way I was paying that out of my pocket so the silly bugger went through insurance.
Posted: Thu Nov 21, 2013 7:54 pm
by storminmike
[quote="nujon"]
The wife has an X5 so it's double the pain
4 new tyres on hers
door handle carrier
new steering wheel cover too
her mid is pixelated quite bad
has a bit of a first gear jump when warm
[quote="Bargain Bucket"]
still to fix
PDC tone front
Must get a scanner really. Facelift fronts are a PITA and I replaced one....and broke one wing mount a bit
If I take the bumper off again ut just mgh be all 4 I swap,,,,but then again I have an unused wing mount for the bumper gathering dust> Will have to wait for the summer
2 new rear tyres coming on Sat courtesy of Event Tyres....bank balance might take a rest after that
having said that I get 2 mpg more now it's warming properly.....
still baffled how a pump would make it warm properly...but it does...............toasty
Posted: Thu Nov 21, 2013 10:28 pm
by Colin
Hi all , my temp gauge only goes to the tick above the blue even after long drive , so is my heat system faulty ? where should needle be , normal, on a (05 e53 diesel ) Thanks ...
Posted: Thu Nov 21, 2013 10:39 pm
Temp gauge should be smack upright in the middle. If it's below then you may have a dying thermostat which may keep the engine in 'cold' operating mode for longer and burn more fuel.
R
Posted: Thu Nov 21, 2013 10:56 pm
by Colin
Thanks R , I also notice after a long drive today (120 mls ) the aux heater was running ?( it was only 4 deg outside ) i could here it at traffic lights and when i got home , Thanks ,Colin ...
Posted: Fri Nov 22, 2013 7:01 am
by fenj66
aux heater should run below 5deg C until engine is up to normal temp.
sounds like you defo have a stuck thermostat then if its having to run all the time.
shove a bit of cardboard accross half the radiator to block the cold air flow - thats what i used to do with my old cortina!!!!
worked tho
Posted: Fri Nov 22, 2013 7:19 pm
by storminmike
[quote="COLIN"]
mines a 54 plate diesel and as the OP of this thread I can tell you it should be bolt upright. In this weather with the fixes I had it takes 4 miles ( or less) ro get vertical whereas before this week after 40 miles in never got above the first tick.....and the cabin temp was rubbish
Thermostat is the most logical (and cheapest part) to look at. Strangely (and I have no reason to doubt the indy) the thermostat wasn't the problem with mine but a £100 auxillary pump.
The pump apparently came up on diagnostics being electrical and all that but mine may have been a one off
Posted: Fri Nov 22, 2013 8:33 pm
by Colin
Thanks Storminmike i hope its my stat thats faulty and i will get it changed as soon as , strange i never caught on mine was faulty until i read your post thats when i put 2 and 2 together, how long its been that way ...who knows , Thanks again . Colin...
