Page 9 of 11
Re: Reverse Camera Install (E53)
Posted: Mon Jun 17, 2013 10:04 am
by LincsX5
This is still on my to-do list but I'll be using the PDC supply now. As for the Con, does it de-activate if you turn PDC off with the button?
Was it this kind of relay http://www.maplin.co.uk/pcb-mount-low-p ... elays-2512 it has a coil resistance of 400 Ohms.
Posted: Tue Jun 18, 2013 1:12 pm
by jaynana
it does activate and de-activate when you on/off PDCs with the PDC switch. so that is quite handy too.. to activate and de-activate it manually.
relay is something like the one you've shown. tbh i just can't pin point exactly what i bought because i just walked into a maplin and talked to one of the nice ladies there and picked up a relay lol. but its something like what you've shown..
Posted: Tue Jun 18, 2013 7:48 pm
by LincsX5
Thanks, definitely handy that.  I soon as I get the garden finished and get the skip off the drive I'll be tackling this mod.
Posted: Sun Jul 21, 2013 7:53 pm
by psychosis
Almost embarrassed to admit this but I'm struggling to remove the tailgate grip piece to start fitting my camera. I have undone the 4 t20 screws but can't seem to get the handle to move at all. I am very concerned about breaking anything but are there any clips etc? Any tips for removing this?
Posted: Mon Jul 22, 2013 10:23 pm
by jaynana
from memory (which prob has faded - its been a while) there were no clips and nothing else holding it in..
Posted: Mon Jul 22, 2013 10:54 pm
by Sanj
There are none, just the 4 screws then it falls out. Prise it out wards with something plastic (trim removal tool, if u have one)?
Posted: Mon Jul 22, 2013 11:07 pm
by psychosis
I do have a trim removal tool that I was using. Will have another try. At least there are no clips to break. Cheers guys.
Posted: Sat Jun 14, 2014 9:58 pm
by Zakbelle
Hi sanj, what is the spec of the relay you used???
Posted: Sun Jun 15, 2014 1:28 pm
by Sanj
[quote="Zakbelle"]
Try this.
Posted: Sun Jun 15, 2014 2:29 pm
by Zakbelle
Great thanks sanj seen one in maplins roughly the same price, just worked out I'm gonna have to split my RCA connector to +/- to connect up to the tv module!
Posted: Sun Jun 15, 2014 2:47 pm
by Zakbelle
Sanj if I use the relay will I still get the canbus error if I use the led light supplied with the light?? I've just spoken to the seller who instals them and basically said don't listen to forums but take it to him and he would have a go at fitting it for a pretty Hefty fee!! Lol  the instructions look pretty crisp and sorta regret not going down your route of the separate camera now. Here is the eBay item number 400722316021 can you have a look and see what you think??
Craig
Posted: Sun Jun 15, 2014 4:07 pm
by Sanj
That will give you the error for sure. Not because of the relay but because of the LED bulb (unless it's error free). Do a dry fit and test it - will be interesting to see how that gets installed where the current lights are (there's not much room there and the holder is quite big).
Posted: Sun Jun 15, 2014 5:46 pm
by Zakbelle
Yeah I spoke to the supplier sort of today on a bad line and he didn't answer the question of canbus errors. Is there a way round this? Can I mimic the Oem installation and fool the canbus into thinking that the conventional bulb is fitted?? Is it a resistance issue??
Re: New 2 bmw
Posted: Sun Jun 15, 2014 9:11 pm
by Sanj
It is a resistance issue, but the space in there is hugely restricted. If you can send the unit back, do so. Dispute it as sending you errors and Paypal should settle in your favour. Then get the one like mine.
Posted: Mon Jun 16, 2014 8:33 am
by Zakbelle
Sanj how did you get it leak tight and can't actually see yr type, I have looked
