Picking up E70 X5 in a week, what to look for?
Ac505
Post by Ac505 » Sun Jan 05, 2014 5:24 pm
hello all. First post here, so be kind!
I'm picking up my new (to me) X5 in a week or so. 3.0D with Dynamic pack, Panoramic roof and comfort seats, 55K miles.
I've read up on the various roof issues so will be looking to make sure it works and doesn't leak.
What else should I be looking for, standard faults etc.
As a bit more info, it has just recently had the rear discs and pads done and two new springs at the front (one had cracked).
Reusch
Re: Picking up E70 X5 in a week, what to look for?
Post by Reusch » Sun Jan 05, 2014 8:26 pm
Welcome make sure you check everything roof,stereo,heater etc etc etc.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
535dboy
Post by 535dboy » Sun Jan 05, 2014 8:38 pm
Welcome
How old is it?
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
X Box
Post by X Box » Sun Jan 05, 2014 8:50 pm
Congrats and welcome.
People buy horsepower but drive torque!
Wakey
Post by Wakey » Sun Jan 05, 2014 9:21 pm
Bmw dealer, dealer or private?
Ac505
Post by Ac505 » Sun Jan 05, 2014 9:41 pm
It's a 2008, buying from Deutschmarque in Edinburgh.
535dboy
Post by 535dboy » Sun Jan 05, 2014 9:42 pm
Check roof very carefully then
Also check for battery warnings.
Currently :
2012 Audi RS4 (B8)
Previously :
martin33100
Post by martin33100 » Sun Jan 05, 2014 10:53 pm
If it has 20's and sports suspension I would take it for a long drive to make sure you are happy with the ride, also check for rattles in the boot as this seems to ba a common issue on the E70. Our E91 I traded in had no rattles or noises at all and I handed over another 10k to buy this thing ::)
As above check the roof well, after reading lots of posts on the panoramic roof I opted  not to have one, it appears the glass roof it too heavy for the cables and they stretch after a while and put it out of alignment, I have even seen a BMW rebuild kit with new cables/ runners.
After you buy your car you can check to see if the rear inner light gaskets have be added, did our 57 plate and they were around £10 a side from BMW, the offside light gave up before xmas so some damp got in before hand anway.
Check coolant temps on the hidden menu and should be around 90 deg c, changed both stats on ours as they were a little low and gained a couple of mpg.
Also get the codes read, I found out we have a glow plug controller gone down. This is a common fault as we had the same go on our 07 plate 325d.
hertfordshire1
Post by hertfordshire1 » Mon Jan 06, 2014 12:47 pm
Congrats on the purchase.
I would check tyres (these are expensive to replace and tend to wear on the inner edges) rear.
Steve
Cheers,
Steve
40d M Sport E70 X5 (mapped)
BMW E34 M5
Suzuki GSX-R 750 (K8)
Past:
Jaguar XF-S / Merc SLK 55AMG / BMW 330d Touring / Range Rover Vogue SE SuperCharged / Audi RS4 (B7) / Renault Clio 172
535dboy
Post by 535dboy » Mon Jan 06, 2014 12:51 pm
[quote="hertfordshire1"]
Steve
True so get right down on the floor!!!
Currently :
2012 Audi RS4 (B8)
Previously :
Caesium
Post by Caesium » Mon Jan 06, 2014 3:41 pm
Make sure the air suspension on the back works, easy to do.
Take it for a run and when you pull up and get out it should pump the back up and you'll hear the compressor and see the back rising up.
Like so..
http://www.youtube.com/watch?v=9bNzuZ1LKNU
Doesn't ALWAYS do this, but most of the time it does on mine,
Open and close the pan roof at least five times, all the way back and also up and down. If that fails then walk away or negotiate a better deal as they can be very costly to fix.
Currently :
2013 BMW E70 X5 40D MSport
Previously :
2008 BMW E92 335D MSport
2004 BMW E46 M3
2005 BMW E60 535D MSport
2002 BMW E39 530D Sport
The list goes on...
Benstan
Post by Benstan » Mon Jan 06, 2014 5:38 pm
I'm embarrassed to say that I never knew what that noise was until now.  It's pretty quiet on mine, and I figured it was something important, but didn't know what.
B
Current: 2012 X5 MSport 3.0d - carbon black, 3rd row, panoramic, media, TV, top-view camera, power boot.
Former: 2006 520d SE (E60) - auto, black leather
martin33100
Post by martin33100 » Mon Jan 06, 2014 9:25 pm
Talking about noises does anyone get a noise when the climate control is on?.
Its a faint hum that pulses high and low at about a 4 second interval, turn the climate off and it goes straight away and then comes back as soon as you put climate back on.
Air con is off though, just heating.
Caesium
Post by Caesium » Wed Jan 08, 2014 2:08 pm
[quote="Benstan"]
B
You're welcome
Currently :
Previously :
2004 BMW E46 M3
The list goes on...
Caesium
Post by Caesium » Wed Jan 08, 2014 2:09 pm
[quote="martin33100"]
Could be the heater control flap motors cycling.
Currently :
Previously :
2004 BMW E46 M3
The list goes on...
