Auto Folding Mirror Fix
How-To articles ONLY go here.
Busapower
Re: Auto Folding Mirror Fix
Post by Busapower » Wed Feb 16, 2011 9:20 pm
Thanks for your reply, kind of thought that but always better to ask. Has anybody used the above suppiers that are on this thread that might have a part number for the switch and who they phoned to get it.
Thanks.
nujon
Post by nujon » Sat Feb 26, 2011 1:59 pm
I've used Radio Spares (RS) for electronic/electrical bits for various purposes over the years - always found them OK - they would be my starting point
Gurbinder
Post by Gurbinder » Wed Jun 01, 2011 9:36 am
would this solution also cure the clicking i get when the drivers mirror folds in and trys to bounce back out.
thanks
03 53 M3 CSL SG 10.5K
03 53 4.6IS BLK/BLK
12 12 Pathfinder 2.5 DCI Tekna
mrb0011
Post by mrb0011 » Thu Jun 16, 2011 9:32 am
Hi Gurbinder
Your problem sounds similar to mine which I believe is related to worn cogs in the motor assembly.
Does anyone know whether these cogs or the motor can be sourced separately?
Any suggestions would be gratefully received.
Michael.
2004 54 X5 3.0D, E39 M5
AW8
Post by AW8 » Fri Aug 19, 2011 8:11 pm
Decided to look at mine today - found it easier to pull covers off applying pressure around edges & not just to side.
Metal cam/spring on rear of the Burgess microswitch was completely off & nearly swallowed into near the nylon hinge pivot on offside
Used tweezers to remove it. I had to try to reform it using heat via gas hob so as less brittle.....then refitted to the switch being careful not to shear tiny plastic tabs.
I saw on xoutpost someone worked out which part these were- hence my "Burgess" reference. The switches on car have wires going right into same so if sourced these would probably need to be fitted by cutting wires, soldering &/or or using watertight connection blocks
I couldn't take pics due to lack of readily available charged equipment - Sorry.
HTH someone. Thanks to Sanj for this original How- To :thumbsup:
pvr
Post by pvr » Sat Aug 20, 2011 11:51 am
So did it work?
AW8
Post by AW8 » Sat Aug 20, 2011 2:30 pm
Yes - working :)
Have emailed various u.k. stockists of Burgess switches to see if they will sell to me direct.......so I & or other members can source& keep spares.
Not hopeful of a positive reply but it would be good to find a stockist for these switches........Will update here if I can find a helpful supplier.
Ansamoiz
Post by Ansamoiz » Thu Jan 26, 2012 11:59 am
I am having difficulty in removing the cover. Is there only one clip on the side? Which way should I push the cover?
PhilUK
Post by PhilUK » Thu Jan 24, 2013 12:20 pm
Any news on finding a supplier for these micro-switches anyone?  :(
E70 X5 35d M-Sport
E53 X5 3.0d M-Sport
Sold
UrbanFlow
Post by UrbanFlow » Thu Jan 24, 2013 6:36 pm
Phil UK,
I've just ordered a new motor, gears and metal internal cover for my mirror from this company in Taiwan. They also sell the micro switches:
http://www.hongmei.com.tw/?fits-to-bmw-outside-mirror-parts,17,3
Current Rides:
Previous Ride:
2003 Silver 3.0i Sport E53 X5
LincsX5
Post by LincsX5 » Thu Jan 24, 2013 7:12 pm
I've looked at the same site before, but that was as far as I got. My ns mirror is a bit loose and will move back a bit when I have towing mirrors on. I will be very interested in seeing how you get on. Sounds like an excellent opportunity for a How-To  :thumbsup:
2008 E70 3.0D SE Dynamic kit
2006 SAAB 9-3 Aero
2004 E53 3.0D Sport. Heated steering wheel, Remote Aux heat, Arches, Skid plate. SOLD
2002 E46 318Ti SOLD
1972 Triumph Spitfire
PhilUK
Post by PhilUK » Thu Jan 31, 2013 2:54 pm
[quote="UrbanFlow"]
Phil UK,
Thanks. Just sent them an enquiry.  :)
E70 X5 35d M-Sport
E53 X5 3.0d M-Sport
Sold
X5LeMans
Post by X5LeMans » Sun Feb 03, 2013 9:22 pm
Is wear in the switch likely to cause the mirror to power all the way in until it actually hits the door, or is there an adjustment for that. My mirrors work, but the passenger site either needs adjustment or repair I assume. (At the moment, the solution is not to use them. But they are handy when trying parking on the street.)
X MAN
Post by X MAN » Sun Feb 03, 2013 10:37 pm
[quote="UrbanFlow"]
Phil UK,
Found this european supplier selling X5 E53 mirror repair kits on Ebay.
http://www.ebay.co.uk/itm/261159885740? ... 26_rdc%3D1
05 X5 3.0d
MarkW
Post by MarkW » Wed Apr 03, 2013 9:56 pm
When I try to fold my mirrors, the drivers one folds in and immediately out again, the passenger side just makes an awful noise and doesn't actually move. I noticed when cleaning the car the passenger side moves slightly, feels a little loose. Could both problems be switch related?
X5 3.0D Sport, Estoril Blue, Black Nappa leather, Sat Nav, Bluetooth, Pan Roof, Rear Screens, TV.
