Rear fog light not working - what does this idiot try next ?
Posted: Sat May 17, 2014 1:04 pm
by Ant
The Worlds worst mechanic is back, my car has told me to check my rear fog lights, so I did, it was not wrong the nearside one has given up the ghost.
I impressed myself by removing the black plastic slidy thing on the lower tailgate, then removed the offending fog light bulb, Swapped the bulb for a spare and it still did not work. So like a dope I put it all back together and looked online for a bulb holder (my thinking being if its not the bulb try the bulb holder next), then I remembered there is one on the other side, so I went and took it all apart again and swapped them over. Again the nearside one does not work.
So even I can now see that the bulb and the bulb holder are both OK, but what do I look/test next ?
By the way the reversing light on the nearside DOES work, so what am I looking at here ??
Is it the wiring ? and the black plug thing that carries the current to the unit.
Is it the actual light cluster ?
Any help, as always, is appreciated
Re: Rear fog light not working - what does this idiot try next ?
Posted: Sat May 17, 2014 4:05 pm
by Horizon
Could be a bad earth/ ground connection. You will need a multimeter to check to see if its a bad/ missing positive or ground connection. One that can read 12v DC.
Without a meter you will have a problem diagnosing the fault.
Posted: Sun May 18, 2014 1:59 pm
by Ant
How about one of the screwdrivers with a light on the end ??  :(
That's about as technical as I get
