Drivers Footwell Flooded!!
Raward
Post by Raward » Thu May 22, 2014 10:23 am
Yikes!
Went to get in the car this am and water poured out of the foot well.
Car is parked on a grass verge with LHS of car on the incline so water would tend to pool on R side if that makes sense.
Rained a lot of course overnight.
Is something blocked?
RAW
2003 X5 pre-facelift
Cockneyjanner
Re: Drivers Footwell Flooded!!
Post by Cockneyjanner » Thu May 22, 2014 10:34 am
I've not experience this on my X5 but have had a similar problem with a previous car. It was caused by the drain tubes from the sunroof surround being blocked, which caused rain water to run down inside the interior trim rather than out through the bottom of the car. Mine was nowhere near as bad as yours though, and only caused saturated carpets.
It's not the Days in your Life - It's the Life in your Days  8)
Raward
Post by Raward » Thu May 22, 2014 10:43 am
Yes it started a few weeks ago as wet carpets but this morning was comical......half expected some fish to be flip flopping about!
Cheers for the advice!
RAW
Post by X5Sport » Thu May 22, 2014 10:46 am
Also check behind the door cards in case the membrane has detached which will allow water in too.
Raward
Post by Raward » Thu May 22, 2014 5:40 pm
Blockage in driver side sunroof drain unblocked with a twig!
Loads of water then pissing from drain under driver side of car.
I wouldn't advise using a twig for obvious reasons.
RAW
Post by X5Sport » Thu May 22, 2014 7:44 pm
Glad you found it.  At least the weather should be improving so the carpets can dry out again.
Cockneyjanner
Post by Cockneyjanner » Fri May 23, 2014 10:33 pm
Result!
Glad you sorted it  8)
