Check Brake Linings!
Posted: Wed Dec 15, 2010 8:06 pm
The warning has just appeared on our E53. Any idea as to approx how long it will be before they actually need replacing? I am ssuming you get a little time before ending up with all metal braking!
The other question is - how do you know which set the warning refers to? The car is still on its original pads and rotors at about 46,000 miles. It seems a little odd that BMW go to all the trouble of adding driver protection and warning information systems, but then don't tell you which end on the car needs looking at. I don't expect all the wheels need doing and am assuming it is more likely to be the fronts given that most of the braking effort is generally applied to the front brakes - hence larger braking units at that ebd.
Anyone know of a good place to get pads from - assuming I don't need OEM - and is it 'good practice' to do the rotors as well? If so from where? Any recommendations from those who have DIY'd it? It does not look like a major job but I have no guide on what needs to come off in what order and what other parts must be done at the same time.
I know I can get some 'how to' info from Xoutpost.
