Another parking sensor problem
When I select reverse I get a beeping from the front sensors, this happens about 8 out of 10 times and sometimes stops while I'm still in reverse and sometimes continues until I select anther gear. I have listens for the sensors clicking which they all appear to do, but when I stand in front of the 2 front left sensors they don't make a beeping in the car, so does this mean they are both at fault (even though they both click) or is there another issue?
2004 X5 3.0d
Re: Another parking sensor problem
I would connect INPA. It will tell you exactly which sensors are at fault and then you just replace them yourself.
Quite a straightforward job.
