fan on when starting car
Jayx5
Post by Jayx5 » Sat Sep 06, 2014 11:45 pm
Every time I start my x5 when cold the fan runs and sounds like a space ship going down the road, it lasts about 200m and then cuts out. Does anyones v8 do that?
2010 space grey se dynamic pack and lots of toys
Ryoken
Re: fan on when starting car
Post by Ryoken » Sun Sep 07, 2014 11:32 am
mine does the same , isn't it the AC fan firing up as well ?.
2002 e53 4.4  tempremental
Jayx5
Post by Jayx5 » Sun Sep 07, 2014 3:15 pm
Mine does it with the air con off!
Post by X5Sport » Sun Sep 07, 2014 4:10 pm
Have you got it in a recirc mode?  Just thinking out loud.
Smeeagain
Post by Smeeagain » Sun Sep 07, 2014 5:48 pm
[quote="jayx5"]
What make/model/year of space ship does it sound like?
Smee
Jayx5
Post by Jayx5 » Sun Sep 07, 2014 8:47 pm
Lol, it actually sounds like a old 2.4 diesel toyota engine! The fan does seem to come on a lot when driving as well could it be a dodgy thermostat?
davesavage257
Post by davesavage257 » Mon Sep 08, 2014 6:47 am
There are two fans on the X5, the main engine cooling fan (between the radiator and the engine) and the auxillary air con fan (in front of the radiator, behind the grill).
The main cooling fan is driven by a viscous coupling, old way of testing is to roll up an old newspaper and carefully push into rotating fan blades when running. If it stops the fan you need a new coupling. A good coupling will bat the newspaper away.
The auxiliary air con fan is electrically driven, switched by a PWM signal from a control box.  It should run when your air con is on to help cool air over the condenser.
The normal failure of the aux fan is to stop running, it may just twitch if you watch it when the snowflake air con button is pressed with engine running.
Hope that helps.
2003 BMW X5 4.6iS Sapphire Black
Jayx5
Post by Jayx5 » Mon Sep 08, 2014 9:18 am
Ok thanks will give that a try.
Ubatoid
Post by Ubatoid » Mon Sep 08, 2014 8:39 pm
Perfectly normal. what happens is the sticky goo collects in the bottom of the viscous unit when left for a long period and this locks the fan until centrifugal force puts back on an even coating. The pusher fan should do a quick self test when starting, ie a quick spin up and then stop.
2002 4.4 cooking on gas
Jayx5
Post by Jayx5 » Mon Sep 08, 2014 9:23 pm
Nice one that's put my mind at rest until the next problem. :))
Post by X5Sport » Mon Sep 08, 2014 9:29 pm
Nothing like a new bit of viscous coupling.........ask 535dboy >:D
