Whats the second fault? Could this be an injector? The car sometimes vibrates when stationery but is fine when driving. Can I check the injectors with scanner.
Uploaded with ImageShack.us
All help much appreciated
It seems to be a function of the ECU which detects mis-firing cylinders. I guess a glow plug could be the root cause of this and/or dirty injectors, fuel or fuel filter etc.The engine smoothness control facility balances out the speed fluctuations of the individual cylinders caused by different injection quantities and degrees of cylinder efficiency. This is achieved by rapid application of controlled corrected injection quantities for each cylinder.
