Gearbox oil change
Dixie
Gearbox oil change
Post by Dixie » Tue Dec 30, 2014 8:42 pm
Hi I've recently bought an 06 3.0d sport and just for piece of mind I got a diagnostics done! It came back with gearbox oil worn! I assume this just needs an oil change? What oil is recommended?
Dan Alex
Contact:
Re: Gearbox oil change
Post by Dan Alex » Tue Dec 30, 2014 8:49 pm
i reckon it's a 6 speed right? ZF transmission that is....
Do you have any idea what the diagnostics revealed? What error code it yielded so that they interpreted it as a  worn out oil?
You'd have to change the oil, oil filter, gasket, and oil pan screws. (out of which filter and oil- compulsory, of course) the rest, rather optional in my opinion.
Do you have any other symptoms when worn oil is involved? jerky shifts, etc?
Try to do a full oil change, flush, not partial.
P.S. I'm very interested as i have some issues with mine, as well...
"What's in a name? That which we call a rose, By any other name would smell as sweet."
E53 3.0i Sport
Ducati 749 Dark (AKA - the rattle)
Previous: Merc 230 kompressor
                Dacia Sandero :)))
Dan Alex
Contact:
Post by Dan Alex » Tue Dec 30, 2014 8:54 pm
Two topics south ....
ZF Services UK Ltd.
Abbeyfield Road
Lenton, Nottingham NG7 2SX
Email: [email protected]
Phone: +44 333 240 1123
Fax: +44 115 986 92 61
Homepage: www.zf.com/uk
E53 3.0i Sport
                Dacia Sandero :)))
Dixie
Post by Dixie » Tue Dec 30, 2014 9:02 pm
Yes it's a 6 speed! Gear change is 100% very smooth! The mechanic had just told me the code read gear oil worn! I just can't seem to find the correct oil! He did warn me that the oil was expensive and that cheaper oils were available but I don't want to chance it after reading some horror stories!
Dixie
Post by Dixie » Tue Dec 30, 2014 9:04 pm
Thanks for the reply but I Live in Northern Ireland! I just need to know the correct gear oil to purchase
Dan Alex
Contact:
Post by Dan Alex » Tue Dec 30, 2014 9:16 pm
Since you have a ZF box, what i would do is to pop a question to these guys at ZF, to be on the safe side !!
But then again i'm very curious what others that have dealt with this might have to say HERE....
E53 3.0i Sport
                Dacia Sandero :)))
Post by X5Sport » Wed Dec 31, 2014 9:43 am
There is a specific error code for the oil, you'll find it in discussions on this Forum - mainly in the E53 area.  Yes it just means changing the oil and filter.
Dixie
Post by Dixie » Wed Dec 31, 2014 9:54 am
Thanks, what oil is recommended I can't get through to my local bmw dealer! Is oem oil the only way to go or is there an alternative that is just as good?
Post by X5Sport » Wed Dec 31, 2014 10:20 am
Have a search on here for the oil type.  It does need to be the right one with the ZF boxes.  It isn't cheap either.
Denis O
Post by Denis O » Wed Dec 31, 2014 10:26 am
I believe member "kkx5" has recommended an oil which is much cheaper than your friendly neighbourhood dealer will sell you. Dealer will also tell you your car will self destruct within 3 miles if you use any other oil but then they would wouldn't they. Some people even believe it.
From what I've seen "kkx5" seems to know what he's talking about in these matters. Search his posts and you'll find the 1 on auto box oil changes.
05 Mercedes SL350
Dan Alex
Contact:
Post by Dan Alex » Wed Dec 31, 2014 1:47 pm
Thanks Richard!
E53 3.0i Sport
                Dacia Sandero :)))
Dixie
Post by Dixie » Wed Dec 31, 2014 4:15 pm
Spoke to an auto gearbox specialist today in Dublin who informed me that it's the transfer box that flags up that fault not the gearbox its self! Can anyone confirm this as he has quoted me a decent price for servicing the gearbox and the transfer box?
Post by X5Sport » Wed Dec 31, 2014 8:12 pm
Sounds right.  It's been seen before on here too, and  the oil changed.
stevox5
Post by stevox5 » Wed Dec 31, 2014 10:27 pm
That is correct the transfer box oil change service life will flag up as a fault code hen it's due for replacement . This is not the case for the gearbox .
X5 3.0i Topaz Blue , Paddle shift steering wheel , Pioneer double din sat nav,Alpine speaker upgrade,  Remap, HID's,20inch lemans alloys,lemans arch kit,Depo light kit,carbon fiber interior wrap.
centurion
Post by centurion » Thu Jan 01, 2015 12:07 pm
All info re gearbox should be on the sticker (red/green) that is affixed to the g'box... Quick look underneath should reveal what is 'in it'.
Also if you INPA it should provide an info re type and make of oil being used.
Hope that helps
