Battery discharging
lentil
Battery discharging
Post by lentil » Fri Mar 27, 2015 10:55 am
For the second time now, my battery has completely discharged. What I find strange is the car can be left for a week quite regularly and then it starts up with no sign of weakness, yet the problem arises when i've driven to work, it is left all day, and when I return to the car it is completely dead.
Could this be the alternator?
I did notice that my DRL was switched on by accident, but I doubt this would cause an issue as I believe the car goes in to sleep mode after a short time of inactivity?
I have found various information on here regarding discharging batteries, and there are several causes, however based on the information i've provided I am hoping someone can shed some light on this.
Thanks in advance.
kjb1
Re: Battery discharging
Post by kjb1 » Fri Mar 27, 2015 1:57 pm
check the terminal for your jump start under the hood.  Positive terminal, ensure it is fully tight!!!
Sent from my iPhone
kjb1
use a spanner, not just A hand tight check etc.
Sent from my iPhone
lentil
Post by lentil » Fri Mar 27, 2015 2:10 pm
Thanks kjb1,
The local garage have sorted it.
Turned out to be a loose earth connection !  :))
kjb1
Post by kjb1 » Fri Mar 27, 2015 7:56 pm
[emoji106][emoji106][emoji106][emoji106]
Sent from my iPhone
