2004 D-Sport centre console cubby box removal ?
X5-D-Sport
Post by X5-D-Sport » Thu Apr 30, 2015 5:11 pm
centre console cubby box removal ...
How do you get the plastic tub out of the Centre Console ?
I want to access some wiring underneath it...
I lifted the little rubber matt from the bottom, assuming there would be some screws, but NOTHING.
I jemmy'd the edges gently & they lift, and I'm assuming the tub simply pops in & its a pop-out part, but don't want to risk breaking the part ...
Any clues any one ??
Steamyrotter
Re: 2004 D-Sport centre console cubby box removal ?
Post by Steamyrotter » Thu Apr 30, 2015 5:29 pm
If its like the pre facelift then it is a firm pull up.
No fixings but a pain to get a grip on..
Please note...
X5-D-Sport
Post by X5-D-Sport » Thu Apr 30, 2015 6:02 pm
got it....
And YES, its a real bugger...
I wanted to hook an Audio Line-In in the hope I could feed music from my mobile fone into the vehicle systems... but it seems it will only talk to I-fones...
So, is your wife under the back lawn yet Steamy ???
Steamyrotter
Post by Steamyrotter » Thu Apr 30, 2015 9:37 pm
Are you sure it was an audio install and not your pyro????
There is a way to run any audio through it.
You can add an aux input lead to it.
If you have nav then it is relatively easy as you plug a lead in the rear of the head unit.
If not nav then you can break into the CD audio lines and feed headphone output to it.
I have the latter and have put a switch in to select aux or CD.
And nope.  Wifey is all good this end.
Please note...
X5-D-Sport
Post by X5-D-Sport » Thu Apr 30, 2015 10:16 pm
I will see whats involved getting the head unit out some time & have a poke about behind there...
