The x is playing up a little and cranks/turns over for a lot longer than normal before starting.Once started it will run ok but doesn't seem to have full power and i keep getting the 'Fuel injection system' warning flashing up on the dash.
I have scanned it and the warning/code i keep getting is ' Plausibility rail-pressure volume regulated'
Can you shed any light on this for me fella as the x is apita at the mo
I was thinking injectors or maybe a sensor as it doesn't seem permanent (it cut out and died the other day but then re started and ran fine
Any help is appreciated
