Hi all,
I took my x5 (2005) for its MOT the other day and it passed with flying colours! The guy who tested it did point out that the offside rear tyre was scrubbing on the inside so asked him to thoroughly check the bushings etc which he did and again said they were all good.
I had noticed sometimes that the rear passenger side seemed a little lower than the driver side and also noticed it pulled slightly to the left so Im now guessing that either the air bag has had it or the air lines are leaking????
First question is.....how do I check for leaks and if the compressor is working ok?
2. are the "OEM quality" air bags on ebay ok to replace the old ones with?
3. If it is the airbag then is it better to just remove both sides and fit the coil spring kit from ebay?
4. How easy is it to fit the airbags and how easy is it to fit the springs?
Thank you for any input on this.
Paul.
E53 Rear suspension sagging on passenger side.
E53 X5 SE 2005
E70 X5 SE 5S (Shadow package)2009
Z3M 1998 special order (black and red interior)
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Re: E53 Rear suspension sagging on passenger side.
does it appear sagged with the engine running and compressor working?
it would be a serious leak to sag on one side whilst driving.
if, when it appears sagged, if you start the car does it appear to pump up the suspension at all?
Yes it still seems sagged when engine is running, I cant hear any hissing etc. I am guessing that it is driving sagged tho as it has severely scrubbed the driver side rear tyre on the inside tread (1.5 inch approx) and the tyres were new on 15k ago, also there is the issue of it pulling slightly to the left too, its always done it for the year I have owned it and thought it was the tracking, so am guessing this was already an issue.
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
If it only sags occasionally, prob the valve block...
See posting on this forum page - similar issue...
I may be able to help you & save you a heap of money.
well ive just done the coil conversion only been running it a couple of days but think back end is a lot firmer and stable 199 and a little graft im no mechanic took me an hour a side
X5 e53 3.0d 53 plate and Honda vtr1000 fun time
Mine had one of the little height sensor mounts all rusted to sheet. So it was deformed, and the sensor itself seemed to be seized up. The dashboard was complaining about rear auto-level failure.
£30 at the BMW dealer for that bit cured it. I'd say you should inspect those little critters too.
Reno: Alsace, France = only 30 minutes to Germany der Vaterland!
2011 E70 40d well kitted from the factory, RaceChip 375hp
2005 E53 3.0d, manual gearbox, sport susp, RaceChip 278hp
