New to the forum.
Have had a new 1 series since last year which the Mrs drives most of the time and bought myself a X5 (E53) 4.4 Sport for my daily commute which is only a few miles.
Thought it would be handy to have the big motor and I like things with plenty power
Car's in excellent shape for the year, not a scratch and full service history.
Has got a few niggles though that are down to age.
ABS light is on - garage diagnosed, no signal from driver rear speed sensor.
Replaced sensor but still coming on 50% of the time, and same error.
It back in the garage today to further diagnose, looks like connection between sensor and ABS comp, hopefully not an expensive one...
PDC - beeeeeeeep! doesn't work. Diag again and middle front driver sensor.
Garage quoted me £180! so bought one on eBay and fitted myself for £10.
Still beeping though, hoping it's just needing the error reset, get that done today.
If not, looks like wiring...
Rear washer doesn't work, not that bothered about this too much but looks like pump, fuse is ok.
Passenger door lock doesn't always come up - need to take the door card off and grease the lock probably, will do that when I have time and clips arrive.
Steering wheel squeaks - This is really annoying! I've tried some silicone lube around the wheel and tried to spray the shaft under the wheel to no avail.
Might be the clock spring... which doesn't sound like fun...
That's about it and all the other stuff works great and really love the car.
Any hints on the above issues would be much appreciated and to happy to join the forum
