Could someone give me some info regarding rear lights
Gazzi c
Post by Gazzi c » Thu Sep 08, 2016 6:34 pm
I have ordered a new set of rear inner light clusters as my old ones was letting water in but the ones I've ordered are marelli led ones, are they a direct plug and play and will they make my car think that the bulbs have blown because mine is a pre facelift with normal bulbs? Thanks in advance Gaz
E53 3.0i sport, acs foot pedals, acs handbrake lever, acs titanium door handles mirror and fog light inserts, Remus quad exhaust, tinted Windows & E70 3.0 D pretty standard at the mo
Tin
Re: Could someone give me some info regarding rear lights
Post by Tin » Thu Sep 08, 2016 8:01 pm
Did you order the new ones from the dealer?
I replaced one of mine (lci car), new one (from dealer) came complete inc fogbulb.
Gazzi c
Post by Gazzi c » Thu Sep 08, 2016 9:10 pm
No I ordered them off eBay £121 for the pair apparently they are oem
libra007
Post by libra007 » Tue Sep 27, 2016 12:00 am
pre lci and post lci both are LED type. LCI ones has one less bulb that need coding to work with pre lci cars.
fitting is simple replacement. If you ordered the pre LCI that has led (upper part) and a bulb, you will not need any coding its direct replacement.
2009 X5 MSport
Gazzi c
Post by Gazzi c » Wed Sep 28, 2016 12:56 am
Thanks libra007 fitting was fairly easy a real pita getting the sticky sealant off though and I had to rewire one of the ISO connectors as the rust had welded the socket into the light cluster but now they are in and work at treat with no coding needed they are marelli 2006 - 2010 lights if any else need any
Manse73
Post by Manse73 » Wed Sep 28, 2016 2:12 pm
Can you put the link to eBay up please
Gazzi c
Post by Gazzi c » Fri Sep 30, 2016 8:49 am
