HELP.......DOOR WONT OPEN
the shreksta
Post by the shreksta » Wed Nov 30, 2016 8:00 am
hey guys
I opened my drivers door this morning when it was -3 and had to give it a gentle tug to open it,I climbed inside and went to shut the door but it wouldn't shut so I messed around with the lock and latch and a few gentle slams managed to shut it and guess what......now it won't open. The handle moves freely.
I don't know if it opens from the inside as I was late for work so had to leave it.
Any ideas?
IanP
Re: HELP.......DOOR WONT OPEN
Post by IanP » Wed Nov 30, 2016 8:13 am
You might find that the lock mechanism is sticky where the lever from the outside handle attaches and is not returning. If you can open from the inside then get the door card off and get some light oil on it. If it does not open from the inside, you will need the welding rod trick to get in ............
I also found on mine that the operating rod had come loose from the actuator (probably because my son has the subtle touch of an elephant) which gave the same problem
Colin
Post by Colin » Wed Nov 30, 2016 10:37 am
Hi , when its frosty my drivers door won't open either , something in the handle mechanism must freeze  i use the passenger door and reach across to open drivers door , always forget to get a look at it then it freezes
05 , 30d Le Mans Blue Sport
the shreksta
Post by the shreksta » Wed Nov 30, 2016 5:02 pm
thanks for the replies guys, i have returned from work and it has started working again........wtf?
Post by X5Sport » Wed Nov 30, 2016 5:57 pm
A squirt of graphite lubricant - it doesn't freeze - might help.  Sounds like water in the mechanism iced up and that stopped things
the shreksta
Post by the shreksta » Wed Nov 30, 2016 5:59 pm
spray it where the oval rubber grommet is i take it?
so glad its fixed itself..................until the next frosty morning  >:(
Post by X5Sport » Wed Nov 30, 2016 6:03 pm
Anywhere you can get a thin pipe from the aerosol into.  Similar products are used my motorcyclists for chain lube as it is less messy than chain oil.
the shreksta
Post by the shreksta » Wed Nov 30, 2016 6:10 pm
will give it a go
one question i have though is how could the handle move in the normal way without anything happening? surely if it was froze it would not move.
Post by X5Sport » Wed Nov 30, 2016 6:15 pm
I think it is the actual mechanism behind the handle, but not certain as I have not (yet) had one apart.  Those who have will explain better than I can.
Colin
Post by Colin » Wed Nov 30, 2016 6:28 pm
- 6 tonight in south England  so cover up those door handle's
the shreksta
Post by the shreksta » Wed Nov 30, 2016 6:33 pm
[quote="Colin"]
dont have a garage buddy so will have to chance it.
Colin
Post by Colin » Wed Nov 30, 2016 8:36 pm
-4 at yours tonight , pour warm water around handle in the morning before unlocking....... i know water is maybe the cause of the problem  but no worse than rain and unto you get the door card off and get it sorted for good , at least you'll not be late for work again  lol
themoog
Post by themoog » Thu Dec 01, 2016 9:24 am
Inside the door below the lock button is the problem about 10" down. There is a pivot that gets water on it and freezes. It also  sticks when it gets rusty. I've had both internal and external handles not work, then its a very clever procedure to open the door.
Steamyrotter
Post by Steamyrotter » Thu Dec 01, 2016 1:23 pm
Whilst you are at it, spray some silicon spray around the door rubbers as they have been known to stick to the doors when cold..
Had same issue with my E39..
But once got the door open, it wouldn't latch shut..
Had to tie the door to the seat to stop it flapping about until i could get in there to free up the latch!!
Please note...
