Would anyone know why why i engage reverse the passenger mirror moves downwards as it should but will not return to the normal position when i drive forwards.
Thankyou
Mirror
Mirror
B&B by the sea in sunny Bridlington, best rates for members
www.themarina-bridlington.com
Re: Mirror
Known issue with drying lubrication on the motors/gears. It gets stuck. You can diy it and use a ceramic grease.
I think there are a few that have had it if you use the search options.
Re: Mirror
I found that a refresh of the Seat position & mirror settings some times also cures this....
IE, reset your chosen mirror position when in Going forwards gear/park, then save the seat & mirror settings to a seat memory position again.... it may well remind the mirror to return to the correct travelling position when leaving reverse & going into Drive/Park.
