4.8is - cracked open front diff
IanP
Re: 4.8is - cracked open front diff
Post by IanP » Tue May 09, 2017 5:03 pm
^^^^ That's what I thought. Not so much the difference in wheel speeds, but the sudden stop as the front wheels climb off the rollers.
Nat
Post by Nat » Tue May 09, 2017 5:17 pm
I am NOT an authority on this but every time I  have taken  the X5 for an MOT ( I go to the same place every time ) and have had 2 E53's ( 4.4 and 4.8iS) and currently have a 40D every single time without exception the MOT tester avoids the rollers and the brake test is done in a completely different way.
I think it even tells you in the handbook that the X5 should't go on  any rollers / dynos.
I have to tell you I would be looking at the MOT station to make good.
They were in the car and it broke whilst they were testing it.
I am sure they have insurance for this.
centurion
Post by centurion » Wed May 17, 2017 12:31 pm
Thanks Nat... that is the option i will explore too.
I did manage to source 2nd hand diff and the car is back on the road... i hope it will last this time round.
As a "precautionary matter", Oil was drained and replaced in a rear diff as well as the transfer box.
Steamyrotter
Post by Steamyrotter » Wed May 17, 2017 9:42 pm
i hope you didn't put oil in the transfer box???
think that's meant to have ATF in it??
But am assuming you refilled like for like though.
Please note...
centurion
Post by centurion » Thu May 18, 2017 12:52 am
I didn't :-)... a garage that did the work on the diff and suspension replaced it.
