Got these off Ebay,, didnt spend too much incase i made a pigs ear of it.
http://www.ebay.co.uk/itm/161128845831? ... %3AIT
couldnt decide between 2 twins like the big boys have or a modern oval. chose the oval
here are few pics, sorry dont know why they keep appearing sideways, i tried to cut out with a multi tool but a bit big and cumbersome so borrowed next doors Dremel type thing. that is what you need for a neat job and a powerfile is highly recommended.
Its a case of make circle in centre for starters to position it, now it will fit through and fasten but the trims point to the floor so you have to score the plastic trim around the shape of the metal trim and you have to cut it out nearly to the top where the clips are, dont go too far.
then as you see you have to fasten it, i got a bit of ali and pushed it into the lip you can see and 2 screws to fasten.
the trims had a jubilee clamp for fixing to exhausts but remove this . push back into bumper, it feels a nice tight fit but to be safe, i cable tied the rear of the trim where the jubliee was and inside the bumper if you look up you can fasten around the bumper mounting shocker thing,just needs a bit of black silicon to smooth the edges as its impossible to get an exact outline unless you maybe are a surgeon, if you dont like the fact you can see inside the exhaust trim and see a single circle then i just put some black ali mesh inside it to block it off.
very easy, took an hour and half and i think it look much better , hope this helps anyone doing the same.
