abs/dsc warning comes on randomly
abs /dsc 4x4 inactive comes on randomly any help would be appreciated
abs/dsc
0
No votes
4x4 inactive issue
0
No votes
Total votes: 0
Gmdoghunter
Post by Gmdoghunter » Tue May 16, 2017 2:30 am
Help would be great,x5 e53 was running great until last night on the way home when the dsc/abs 4x4 inactive lit up on the dashboard like a christmas tree,any help would be appreciated in trying to diagnose this fault,the codes received from a diagnostic are.
Fault Codes
5F10              not present
DSC: DSC sensor, supply
5E34              not present
DSC: Wheel-speed sensor, air gap, rear left
ianst0028
Re: abs/dsc warning comes on randomly
Post by ianst0028 » Tue May 16, 2017 9:44 am
i'd be looking at the abs sensor first fairly easy to change tbh (if it doesnt break while your pulling it out )
X5 e53 3.0 2002 with LPG
Smeeagain
Post by Smeeagain » Wed May 17, 2017 12:16 am
it could also be the battery as they throw up all sorts of errors on these cars? Disconnect it for 30 mins and then reconnect. Full charge overnight ideally with a  CTEk (or similar) battery conditioner
Of course it may not be the battery but it is quick and easy to eliminate
How old is your battery - if it is over six years old then replace regardless as it will cause you issues
Smee
Post by henrym3 » Thu May 18, 2017 6:08 pm
Doesn't the r/l wheel sensor also cover the speedo and if that is working then the sensor is probably ok and it is the normally at fault ABS module?? worth keeping in mind if a sensor replacement doesn't solve the problem.
Smeeagain
Post by Smeeagain » Fri May 19, 2017 11:16 am
and check the battery
