Post
by X5-D-Sport » Tue May 30, 2017 2:25 pm
The battery voltages are OK, my new battery toggles between 13.9 & 14.1 when driving.
11.9 at ignition 1 key setting is acceptable if she has been idle all night.
the symbol on the Left I think is Tyre pressure.... & the other is center diff lock.
if the diff lock switch is pressed, & at a slow crawl you turn the steering wheel lock to lock a few times, this should unlock the center diff.... You DO NOT want to drive on the roads with the diff locked... it WILL damage the diffs or drive shafts.
Suggest, disconnect the battery & touch the battery connection wires/leads together for a few seconds, then make a cuppa & reconnect the battery... this will probably clear the fault...
These vehicles are Female & can get grumpy for little or no reason.
Hope this helps.
Grant B
