first you need a 1m lenght of 3" which i think is near the standard size, stainless steel, cut to size. any size from 150mm to 200mm depends how you want to fix. i found it best to fasten the tips together to add stabilty. i was going to drill and bolt but stainless drilling was a nightmare. i used a chemical metal type paste which was excellent.
The choice of outlet lenght is purely what you fancy. i saw an X5 in our road and put mine about the same.
another idea i thought of later, to add much more stabilty, i could have used longer tubing and epoxied to th eactual silencer box. it may have worked but hindsight as they say.
heres the ebay link , next day delivery. polished or not to choose from i bought a 1m lenght . asked them to cut to size, 4 x 150 and a lenght left over. no idea what to use it for and as for trying to cut it.
http://www.ebay.co.uk/itm/76mm-3-x-1M-T ... 749.l2649/
Photos are follow on, the secret is , the pipes have to stick straight out so you need to cut out a fair bit more plastic than you would think. it would be great to drill 2 circles and put the pipes through try that and the pipes point to the ground, so you have to then remove more bit by bit to allow then to be horizontal. i sealed the pipes in with Black mastic held with duct tape while it set . roughen the steel to give it something to grip to. if anyone needs any tips gimme a shout. May not be everyones cup of tea but i like em. much better than a naked behind
on fitting to the car. you may find they pull the plastic out a little. to counteract this, i put cable tie over the rear of the pipes then another one linked on and secured underneath, as you tighten the tie wrap it pulls the pipes straight. as a precaution i put 2 small black self tappers through. so finished and no rust .
i am selling the first ones i made if anyone wants them, they are chrome but tend to rust unless polished well.
they cost me more than the stainless version. but £25 all posted will buy them, pm me. they are the last photos.
