Reverse Camera Retrofit problem
extremezmachine
Post by extremezmachine » Thu Oct 05, 2017 5:16 pm
https://youtu.be/yghcNOzyNsE
See video above....
I follow the DIY instructions but when I select reverse... I got this..?? Anybody can assist?
Re: Reverse Camera Retrofit problem
Post by X5Sport » Thu Oct 05, 2017 5:40 pm
Either the camera is shutting down, or it looks as if it is losing video sync so the picture goes to black?
extremezmachine
Post by extremezmachine » Thu Oct 05, 2017 6:02 pm
The camera only active for few seconds before losing picture... while it's active it does have lines...
Is I don't use to bad ground?
graemeX5
Post by graemeX5 » Fri Oct 06, 2017 7:54 am
From the clip it appears to me the horizontal lines conincide with the car beeping pulses and causing the interference. This is like the interference years ago when an unsurppressd motorbike or car went passed and would cause your telly to have lines on it
I think its worth checking the wiring connections to make sure they are secure and not caught/ kinked anywhere. Again it may be worth checking the instructions as to whether the live power feeds for picture and sound need to be separate ? and also whether it mentions about a suppresssor or resistor needs to be fitted.
Graeme
marinaman
Contact:
Post by marinaman » Fri Oct 06, 2017 10:27 am
are there connections on the back of the dash unit to accept an incoming camera then ?  may get one or is there a fitting guide anywhere,  cant seem to find .
B&B by the sea in sunny Bridlington, best rates for members  :) www.themarina-bridlington.com
lezmtaylor
Post by lezmtaylor » Fri Oct 06, 2017 2:43 pm
See Sanj's guide on how to fit rear camera.
I did and it works great.
extremezmachine
Post by extremezmachine » Fri Oct 06, 2017 6:26 pm
[quote="lezmtaylor"]
http://xdrivers.co.uk/forum/index.php/topic,86.0.html
The pictures are no longer available for viewing...
marinaman
Contact:
Post by marinaman » Fri Oct 06, 2017 8:56 pm
seems you need tv module which sadly i dont have  :(
extremezmachine
Post by extremezmachine » Sat Oct 07, 2017 2:33 am
"This is the wiring diagram that works (for the purple connection Ign +12v source I just used the White/Yellow wire and it works just fine)" not sure which wire I need to tap for our e53....
Source
http://forum.bmw5.co.uk/topic/40213-rea ... up-camera/
extremezmachine
Post by extremezmachine » Sun Oct 08, 2017 1:03 pm
Managed to solved the problem.... I use the trigger switch on PDC and most importantly the ignition 12V + I tap to the rear wiper pin13 instead of the reverse light.
However I am facing another new issue... the display on my monitor shows the picture are flipped... ImageImage
extremezmachine
Post by extremezmachine » Wed Oct 25, 2017 4:34 pm
Problem solved... apparently I brought front facing camera..
Just replace with rear facing camera and all good
