In short: car seems to be burning oil when warm (oil gauge in the middle) and idling, but idles fine, has no hiccups nor power drops, no smoke while driving around or starting it up. I'm not sure if a major fault and I should bring it back for a refund, or if this is a non-major issue, or I don't know diesels and/or the car is going through DPF regeneration. No clue for now.
Long story: 2 weeks ago I bought a 2006 X3 2.0d from a dealer. Drove away all happy as I test drove the car for half hour on motorway/town etc, checked fluid levels and caps etc and everything seemed absolutely fine. Car drives perfectly and doesn't miss a beat, just needed new rear wheel bearings and MOT, which were done.
Last weekend while sitting at a traffic light I see a cloud of whiteish/gray smoke from the side window, get out of the car and notice it smells like burnt plastic.
I drive away, all panicky and thinking I am going to have a ton of headaches for this, but when I stop at the next light no smoke. I get on the motorway and no smoke.
I get to the airport and a lot of smoke again, but less than before.
Next day I pick up the car again, drive to halfords and stick some diesel cleaner additive in the car. Warm engine, stop at a traffic light and see it smoking, but less smoke than the previous day.
Call dealer, who replies it may be the DPF regeneration that is causing the smoke. Not too convinced, I take the car to my own garage. My chap there sees the smoke and says it's more than likely burning oil and could be anything, valve seals, injectors, piston rings etc. None sounding cheap and cheerful.
Here's a video I took earlier: https://www.youtube.com/watch?v=AYPbz9eQPw0
Worth pursuing a repair? Or shall I start looking for a refund?
