Trying to still find the slow drain, decent weather so at it all day yesterday.
Im stuck with my multimeterm after reading the excellent post from X5 Sport on how to trace i connected up withe the meter acting as the earth return,
i set the meter to DCA and on the 20a setting.
When with door open and the system still awake it reads 0.15, after the 16 mins it goes to 0.06
i was pulling fuses to see if the figure changed but nothing did. few times i woke the system by fuse pulling and the dvd in the boot spun up and the reading went to 2.35 for few mins then slowy dropped eventually back to sleep at 0.06.
The reading shown on the photo 4.40 that was with some circuits activated, so does that read as 4.4 amps ?
if that is 60ma then that seems a good overnight draw and normal ish, this has only happened since the cold weather in November, been fine from when battery was new in March 2017 95 amp Bosch S4
Can someone tell me how to read this. is 0.15 equal to 150ma and 0.06 equal to 60ma ? or 6a , 4.40 equals 4.4 amps
had battery load tested at garage and he said it was fine but still get small daily drain that would flatten car after around 10 to 14 days if not used.
Thankyou
