HELP! Won't start after replacing glows plugs + glow plug module
PhilUK
Post by PhilUK » Wed Apr 11, 2018 3:46 pm
Hi all,
I should start by saying my 35d E70 was occasionally stalling before I replaced the glow plugs + module. I knew there was an issue with the glow plugs and/or module as it was throwing error codes in Carly BMW so thought I would swap them out to see if it resolved the stalling issue. I have since read that the stalling issue may be due to a faulty injector so that was next on the list.
5 of the 6 glow plugs came out fine but one was just spinning so I left that one in place until I can get someone to remove it in the near future.  O:-)
While I had the intake manifold off I also carried out the EGR and swirl flaps delete.
Put everything back together and it will not start! Turns over fine but just wont fire.  >:(
I did spray some EGR cleaner down the ports to remove carbon so not sure if this may have caused the issue?
Looking at the fault codes I'm guessing the new glow plug module may be faulty or connector not inserted fully but would this cause the car not to start on a warm day?
Any advice greatly appreciated!!  :)
These are the error codes after each start of the car:
Engine/Motor:
  • Glow plug cylinder 1, control - 004212
  • Glow plug cylinder 2, control - 004222
  • Glow plug cylinder 3, control - 004232
  • Glow plug cylinder 4, control - 004242
  • Glow plug cylinder 5, control - 004252
  • Glow plug cylinder 6, control - 004262
  • Rail pressure control valve control - 004332
  • Trottle, Control - 0043E2
  • Boost pressure sensor - 0041AB
  • Power management battery - 004A56
Transmission:
  • Embassy transmission data - 00CF34
  • Message -group error 2 - 00CF2B
Gear switch:
  • Lever invalid position/UNDERVOLTAGE - 00A83A
These are the error codes remaining after clearing down the codes:
Engine/Motor:
Gear switch:
E70 X5 35d M-Sport
Black Sapphire / Tan Leather - LCI Tail Lights
E53 X5 3.0d M-Sport
Sold
Re: HELP! Won't start after replacing glows plugs + glow plug module
Post by Alan Gunn » Wed Apr 11, 2018 5:26 pm
Check all plugs on the engine and intake.
There is one at the back end of the fuel rail make sure it is on properly.
