Wheel Arch Trim? / skirt ? / Flare???
kanewesley
Post by kanewesley » Tue Jul 10, 2018 8:56 pm
X5 E53 3.0D Sport facelift model 2006. Titanium silver Metallic.
I have the above car and have lost a clip on Wheel Arch Trim? / skirt ? / Flare??? from over the front nearside wheelarch.
I'm trying to find one ie on Fleabay but having no luck as I don't know what it's called.
What comes up on Fleabay looks nothing like mine????
Does anyone know it's correct name for searching for a replacement please
sleepyfolk
Re: Wheel Arch Trim? / skirt ? / Flare???
Post by sleepyfolk » Tue Jul 10, 2018 10:58 pm
These are the bits I had to get for mine when I stripped the wheel arch out:
Inner Wheel Arch
Hex head screw & washer x 7 07119902267
Expanding nut x 7 63121374075
Expanding rivet x 4 51481915964
Wheel arch trim
Expanding rivet x 10 51717002953
If they look like this they’re the ones ending 694
Mercedes CLK 320
Audi A6 Quattro 2.4
kanewesley
Post by kanewesley » Thu Jul 12, 2018 12:39 am
Sleepyfolk, it's the actual silver cosmetic wheel arch flare or whatever that clips in place over the wheelarch I need to replace, not the black plastic clips LoL.
Perhaps I have not worded my post correctly.
I just don't know what to google to find one.
Post by Horizon » Thu Jul 12, 2018 7:23 pm
Post a photo on the forum, sounds like your kit may not be OEM
Post by Greydog » Fri Jul 13, 2018 7:13 am
Take a look at www.realoem.com put the last 7 digits of your vin in the search box then check for the part you need it will give a small drawing and part numbers that will help with your search.
You could also try some of the specialist BMW breakers
kanewesley
Post by kanewesley » Fri Jul 13, 2018 7:10 pm
Ive looked on the realoem and the part i need is not on., there is the normal black plastic wheel arch trim but this is a colour coded silver flare what clips in to the wheel arch trim
Post by henrym3 » Fri Jul 13, 2018 10:48 pm
I will be keeping an eye on this post as I know exactly the part your looking for and i’ve had no success finding it either.
qsilver7
Post by qsilver7 » Sun Jul 15, 2018 5:46 pm
[quote="kanewesley"]
A picture is worth a thousand words...since you can't find it in the parts database...and none of the suggestions offered up to this point is correct...a picture of what you're asking about would help us help you better.  :)
In fact, your build sheet (VIN decode) may be required to get to the bottom of your request.  If you have options that we are not aware of (especially since we are working in the dark in not even being able to see what you have)...be prepared to offer up that info or look it up and supply it so that we can be more helpful.  :)
There are multiple wheel arch trims depending on how the vehicle is optioned...for example, even the regular wheel arch trim has TWO different part nbrs to accommodate different wheel option...take note of #1 & #4 in the first diagram below.  If you have option code S2KDA, then the arch trim has a different part number.  If you have the aluminum footplate...the trim has a different parts diagram...thus, slightly different parts/part nbrs to accommodate fitment differences:
[align=center]{regular wheel arch trim}
http://bmwfans.info/parts-catalog/E53/E ... heel_arch/
{aluminum footplate wheel arch trim}
http://bmwfans.info/parts-catalog/E53/E ... footboard/
Image[/align]
Post by henrym3 » Sun Jul 15, 2018 8:27 pm
This is the piece I need Image
Just to add to this. These bits, about 6 to each wheel arch are what hold the extra bit of arch on on the 4.6
