Halo light upgrade?
Halo light upgrade?
Hello all I was wondering If someone might be able to explain the differences between the various different wattage available on H8 led bulbs?? Is it actually safe to put a 90watt H8 led bulb in to my headlight? Surely that would generate serious heat? Any advice would be great my current standard lights are tired and one has failed just looking to upgrade rather than replace. Thanks guys.
Re: Halo light upgrade?
Standard lamp is a 35W. More than doubling that with a Halogen filament lamp will likely damage both the lamp holder and the wiring. LEDs produce less heat but they still need cooling. You are unlikely to overheat anything. What tends to happen is that the manufacturer states the power of the total number of all the LEDs in the bulb.
What are you actually hoping to achieve? The issue with most LED lamps is that they don’t correctly align with the light pipes that feed the Angel Eyes. I gave up looking at simply fitted 35W Halogen MTEC bulbs with a blue filter to bring the colour temperature up. At under twenty quid a set they are significantly cheaper than the LED alternatives.
I would recommend fitting higher wattage bulbs...I recently fitted some following a few warnings of front side light failure the Halo lights no longer work I have check fuses which are ok. I led to believe the circuit shuts down after so many warning....I believe they can be reset as anyone else experienced the same issue..any advise would be much appreciated
I wouldn’t recommend fitting higher wattage bulbs...I recently fitted some following a few warnings of front side light failure the Halo lights no longer work I have checked fuses which are ok. I led to believe the circuit shuts down after so many warning....I believe they can be reset as anyone else experienced the same issue..any advise would be much appreciated
There are a lot of different claims for what are probably the exact same halo lights by different sellers the main thing is any of them look a million times better than the horribly dated yellow light of the old units even if they really only illuminate 2 halos properly and the other 2 dimly
- lezmtaylor
I have a 2002 e53 with xenon lights, lights are the splitteble type so I have fitted halo led rings, been on 12 months and well pleased.
- 2017-03-23 11.40.05.jpg (167.31 KiB) Viewed 9146 times
