Post
by sid10 » Tue Oct 08, 2019 11:19 pm
I bought a 40d M sport a couple of weeks ago , tried the 50d but thought it was a bit overkill for what I needed . I suppose it is up to you what you need it for , I havent found the 40d lacking in power 5.9 seconds to 60 , 147 mph , 30 mpg .
Tyres are the first thing I usually check if they are miss matched or budget brand I walk away as it can be a good indication if it is a well cared for example or skinflint owner . 20" are 1k a set , 21" 1500 so barter if near limits .
Service history is kept on the idrive so you can check it plus when the pads , oil , etc will give you mileage or a date when they will need to be replaced . If you buy from a main dealer they will replace pads if car says they are less than 4000 miles until they need changed , oil service is conditional so can fluctuate a bit . But again main dealer will service if you push them hard enough , they also offer a 12 month warranty that covers everything apart from consumables which can be extended after the 12 months which is worth while continuing for peace of mind .
My car also came with a 5 year service pack which the first owner put on the car so check with the dealer if it has one , I dont think BMW management cars could have them on .
The car should look still fresh , paint good , interiors hold up well but check for creaks and damage again bartering tool .
Good luck
Sid10
