rear view camera
askim98
rear view camera
Post by askim98 » Mon May 04, 2020 12:09 pm
hi all,
firstly i own an E70 200 SD
new to the forum, i have an issue since last week where i place the car in reverse and where it should show the stream from the camera is black.
no error messages on the screen and no error message stored tried with INPA and ISTA D .
is there anyway to test if it is the camera faulty or something else?
thank you in advance
David
Re: rear view camera
Post by X5Sport » Mon May 04, 2020 12:45 pm
Probably worth you having a look at newtis.info as it holds the BMW Service instructions as used by the Dealer. Could be a set of test guides in there that would help.
It could be the camera itself, wiring or the video module (it’s by the pedals I think on you car). Check for water in the tailgate too.
Oh and :hi: to the Forum.
askim98
Post by askim98 » Mon May 04, 2020 5:42 pm
X5Sport wrote: Mon May 04, 2020 12:45 pm Probably worth you having a look at newtis.info as it holds the BMW Service instructions as used by the Dealer. Could be a set of test guides in there that would help.
there is no indication on TIS what do do to test but now my next task is to check if i have a video multiplexer.
thank you for your input.
neil50
Post by neil50 » Thu May 07, 2020 12:17 pm
I know it is a basic suggestion but have you checked the fuse?
I am just about to retrofit a reversing camera and I have to route it via the fusebox.
Current
2011 E70 40d 7 seat - remapped
Merc CLK convertible
Audi A2
Smart Car
Previous BMW
E32 - 735se, 735il
E39 - 530d touring
E61 - 525i touring, 525d touring (remapped)
askim98
Post by askim98 » Mon May 18, 2020 2:09 pm
changed the camera and now is all back as usual.
