Hi can anyone tell me if it’s possible to change the trim on a m40 the one like a gold colour to a gloss black one. The trim I’m talking about is the front outer trim near the day running lights. I don’t really want to change the whole trim panel as the expense so I would like to clip this trim out and replace. If anyone knows the part no please share and possibly a link to it
Cheers col
Changing trim
Changing trim
- 529756C1-11FC-4EAA-9955-E9A1D8ECF9BA.jpeg (161.29 KiB) Viewed 25803 times
Changing trim
Have a look at Realoem (BMW Parts database on line) and use the last 7 of your VIN to pull up the right car.
If it is available it will probably be in the Vehicle Trim section, or possibly under Retrofittings.
Changing trim
I did this but didn’t really find anything but if someone does please pass it on
Changing trim
I think you’re right. I can’t see any direct replacement on RealOEM either. From what I know of BMW it would likely be the entire assembly rather than just that part as it will come in from a subcontractor prebuilt. The subbie won’t be allowed to sell it themselves.
Item 3 here: https://www.realoem.com/bmw/enUS/showpa ... Id=51_5781 is the gloss black version but it’s the whole thing and is around £120 per side.
