EGR cooler recall letter
Re: EGR cooler recall letter
It took 4 weeks to get my X3 back from the dealer. However they gave me a brand new 530E (35 miles on the clock) to drive around in. So I was in no hurry to get my car back
Well, today's the day.
I'll update later.
I'll update later.
All clear!
Well that was painless!StuBeeDoo wrote: Wed May 01, 2019 9:53 amAll clear!Arrived around 08hr15. At 08hr30 I was wandering around the used cars, and could see my car getting its "pre-wash". By 09hr20 I was engrossed in the complementary newspaper when the service advisor came to inform me that the car doesn't need a new EGR cooler and I could take it away. Their computer system is down, and he's going to send the paperwork in the post. The only thing they picked-up on the health check is the tyres down to 3.5mm, which I already knew.
Just a heads up for everyone. My EGR cooler was replaced under the recall but they don't change the EGR valve at the same time. If the valve goes down the car goes into limp mode which mine did. Luckily it was replaced at home by BMW assist.
I've had my letter and mine goes in on 31st July. Just wondering if the theme still continues i.e. parts on back order. My dealer has said that the worse case scenario is the car being kept until parts arrive. I've asked them to have a look at the door seals as well as it's developed the known creaking noise.
Known creaky door fault???
Mine went in and came back the same day with the cooler changed. Great service from the garage and the courtesy car was useful but happier to exchange the 118d to the X3
In relation to the squeaky door issue, it's known and if you search for it online you can see many, many posts on the issue and remedy. I let our garage know when it went in for the recall and all the seals were lubricated under warranty. So far they have stayed as quiet as they were when we had it first
Resurrecting this old thread as we have today received the letter saying our car is being recalled for an EGR replacement. No action at this point, they are gathering parts and mobilising the troops in readiness, well get another letter in due course to book an appointment. They claim they will only need the car for 4 hours when the time comes, which seems better than the 4-5 weeks some had to suffer previously
Not sure why our vehicle hasn’t been recalled before (it’s a 2013 30d M Sport). Anyone else had the same letter today?
There's a new recall. Maybe yours wasn't affected by the first one.
My 2012 F25 was recalled in '19, and they said it didn't need a replacement. Then about 9 months later (just before the first lockdown) it was recalled again and they actually replaced the cooler. A few weeks ago I got a letter saying it's being recalled for an EGR cooler replacement, and when I 'phoned them to tell them it's already been done over two years ago they told me they're doing it again.
Found I had a recall on my x5 40d (f15) in July, EGR cooler replaced took around 4 hours in late July along with an oil service. Apparently a lot of the previous recall was inspection and only replace if required, this recall is to replace the EGR cooler with a new and hopefully more robust design.
Actually I’ve just looked back at the notes I made when speaking to the servicing dealers b4 we bought the car (we’ve only had a it a few months). There is a note that it had a used car check at Jardines, Bury St Edmonds in Feb 2019, this included a check of the EGR which I assume at the time did not need replacing.
As Wayfarer mentions above looks like this time it will be replaced regardless, potentially with an improved design.
Booked-in for 7th October. I'm having the coolant fully drained & refilled (at my expense, obviously) while it's in there. This will be the third time coolant has been partially drained and the car is 10 years old, so it seems prudent to me.StuBeeDoo wrote: Wed Aug 24, 2022 3:56 pmI 'phoned them to tell them it's already been done over two years ago they told me they're doing it again.
From what I understand, the replacement coolers used will be post-July '22 production.Big Bad Boris wrote: Wed Aug 24, 2022 4:38 pmAs Wayfarer mentions above looks like this time it will be replaced regardless, potentially with an improved design.
It's just occurred to me........ I wonder if this latest recall is related to the mysterious catching-fire of Police cars.
I wondered the same, but the quiet word on the streets (ex-TraPol) implies incorrect servicing schedules and wrong grade oil. I’m surprised about that (if true) because when I worked with Surrey all out fleet were serviced at 3k intervals and correct parts fitted especially for the high speed fleet. OK high speed back then was what a 2.8 Mk4 Granny and 3.0 24V Senator could do but even so.
Whatever that problem really is, I’d like to know just in case mine has an ‘issue’
I’ve not seen a recall letter but can’t find anything about which models and construction timeframes. DVSA have changed their data views now it’s on Gov.uk and it’s useless!
