OBD scanner
OBD scanner
Well i heard from Carly today, i dont think it's for me.. It's not a fortune, but annual subs are not my thing for something I'd barely use after initial coding.
OBD scanner
I think they are pricing them selves out of the market.
Well for the likes of me who only want to use it 3 or 4 times a year.
OBD scanner
I'm new to all of this stuff and I'm not a mechanic. Therefore much info that's available would probably be wasted on me. I'll look into the Bimmercode option when i return to the UK
OBD scanner
I'm struggling to find a solution to coding as well.
No smart devices, so whatever it is has to be laptop based. I've got the cable, but have been unable to find a reliable source of software.
OBD scanner
I paid £70 for both worth every penny even if you only use it occasionally if something goes wrong anytime you will always be able to scan and see what faults occurring on the spot mines plugged in constantly and regularly do a full scan to check or put dpf section on which shows all temps and dpf info
OBD scanner
Both what.Lobster Pot wrote: Wed May 31, 2023 9:25 am I paid £70 for both worth every penny even if you only use it occasionally if something goes wrong anytime you will always be able to scan and see what faults occurring on the spot mines plugged in constantly and regularly do a full scan to check or put dpf section on which shows all temps and dpf info
OBD scanner
For bimmerlink and bimmercode
Bimmerlink is currently £34.99
Bimmercode is showing as free but I can’t remember if it was paid or you pay once signed up either way they worth there money
OBD scanner
What does Bimmerlink do.
Got Bimmercode and just looked at Bimmerlink and it is £34.99 the same as code.
OBD scanner
Just looked ant is it the fault code scanning it does.
OBD scanner
Bimmerlink does faults service reset dpf and battery registers
Bimmercode does coding including battery coding
OBD scanner
I’m in the process of researching xhp flash tool which looks like it does gearbox faults adaptation and gearbox flashing going to try and connect it with my ipro adapter otherwise it’s £70 for there’s
OBD scanner
I'll look into bimmercode when i return to the UK.
