DSP
DSP
It seems like my DSP has packed up. Sat nav works fine as does the radio (obviously no sound) just the wavey lines of the music. Used ones seem quite pricey bearing in mind they are of similar age. Checked I have voltage going to the amp and the white trigger wire has voltage when the radio is switched on. No water in the hole but I’ll pull it out over the weekend and look inside, unless there’s something very obvious wrong then I’ll have to decide on a course of action. No upgrade or anything like that as it would be wasted on me as my hearing leaves a lot to be desired. If someone has or know who can repair then I can compare prices.
DSP
Cartronics is a name that’s been on here in the past. They’re still about.
Need to send HRH’s Mark 4 nav head to them for a new screen as it’s losing pixels badly now.
