iPhone
- wilkoturbo
iPhone
Hi all I bought this cable off eBay it's av to iPhone it's for the car but I can't even get it to work on the tv in the house I'm I missing something or doing something wrong ??? Many thanks Paul
bmw x5 le mans blue
Re: iPhone
Not possible on the X Paul - the signal strength on the iPhone is not enough for the car...
- wilkoturbo
Re: iPhone
No idea - never tried...
Sorry.
Sorry.
Re: iPhone
hi wilkoturbo
i have these leads in all rooms of my house with the audio linked to my bose system and the video to my tv's
i had to change the setting on the iphone and turn on tv out in the settings on iphone hope this helps . p.s iphone 4
cheers phiggy
cheers phiggy
2002 3.0d black sport auto, now with added mods!!!re-map,chrome clock rings, folding mirrors,wind deflectors,angel eye led hid's,19"sport wheels,reverse cam,ps2 media+hdd,dvd headrests,alpine v12 amp+sub,+alarm chirp !!!!
Re: iPhone
And make sure the TV out signal is set to PAL not NTSC. What's the USB connection for? My Apple lead has Yellow (Video), Red (R.Audio) and White (L.Audio). I'm guessing the USB port is for charging?
Your TV connections should all be to 'Video In' on the TV or video deck.
- wilkoturbo
iPhone
Thanks for all The replys but where are the settings on the iPhone ?? Do these cables work well ??
Many thanks Paul
Many thanks Paul
bmw x5 le mans blue
Re: iPhone
For the iPhone 4 - Settings>iPod> Scroll to the bottom of the options list> Widescreen 'On' and TV Signal 'PAL'
I have a similar cable which goes straight into the AV Amplifier and it works fine on that. Not tried it on the 'X'.
- wilkoturbo
iPhone
Many thanks I've tried it on the tv and works fine for only a min what does this mean on the cable ???
bmw x5 le mans blue
Re: iPhone
I just did a google search on "Firmware 2.21"
It's possible it could be the firmware requirements for the iphone.
Looks like it should work with firmware 2.21 and above.
- wilkoturbo
iPhone
Is firmware a legal copy or does it need to be jailbroke? How can i tell what firmware i have on mine?
Many thanks
Paul
Many thanks
Paul
bmw x5 le mans blue
Re: iPhone
I don't know which firmware it refers to. That symbol indicates 'Less than or Equal to'. To me that means it's designed for a firmware version of 2.21 or earlier. If the symbol was reversed then it requires Version 2.21 or later. It could be an error on the label, or it could be designed for ipods not iphones?
- wilkoturbo
Re: iPhone
If you have an iphone 4 you'll be using higher than 2.21 I think 2.21 was on the 3G.
How to check iPhone firmware version
Press the Settings from your iPhone SpringBoard to launch Settings Menu.
Press General from Settings Menu
Now go to About from General Menu
Under about screen you can check iPhone firmware version under Version Label
Current: E53 Facelift 3.0d Sport Exclusive, Sterling Grey/Black Nappa Leather, comms, 20"'s, heated steering wheel :p just remapped by Jason @BW Chiptune.
(Previous X5 4.4i Sport, Black/Black, comms, 20" 168's)
Also: E31 840Ci
Previous: 911, M5, 540, RR, 30ish BMW's
Also: E31 840Ci
