[quote=""shadrack""]yeh just to update, ive took it very carefully through to another indy i didnt know i was near, it was recommended by who i was dealing with! as luck would have it he has spare time to do it tmoro after he finished some cars tday that were suposed to go to tmoro. anyway he has seen it and recons it will take 30min to an hour using the software to cycle the abs pump, and he gave me a lift back 7 miles to the our yard so i could use a van to go home in!!! so far so good!
Hope you get it sorted tomorrow - took my indy ~ 1hr - he repeated the bleed / ABS cycle sequence twice using 2.5 litres of DOT 4 in the process of getting all the air out. I noted that in the process, he always got his mechanic to open a bleed valve to
before starting the pump sequence - and that the sequence was always stopped
before re-closing the bleed valve - said to do otherwise can damage the ABS pump seals.
