Bonnet alarm switch..........
Post by sapphireblack » Wed Jan 11, 2012 1:34 pm
.....i realised yesterday is not working, maybe it never has in five years :oops:
Does anyone know which fuse this is hooked to? It could easily be that its been disabled by the previous owner so i don't want to splurge for a new swtich if the fuse has just been pulled :)
2009 35d, Space Grey with Chateau leather, still below 40k miles.
Re: Bonnet alarm switch..........
Post by X5Sport » Wed Jan 11, 2012 1:45 pm
I think it goes straight back to the alarm system. Typically it would only provide a ground connection so no power and therefore no fuse required. Causes the alarm to trigger when a 'ground' is provided. At least, that's the way I think it works and matches those saystems I've played with before - which BMW being BMW may not choose to follow as a convention. :?
I take it you've tried the usual open the bonnet, press the lock button and after a few secs let the button go? All hell should break loose if it works. At least, that's the only way I was able to check mine Is the rest of the alarm system OK?
pvr
Post by pvr » Wed Jan 11, 2012 2:31 pm
Normally they fail the other way around, i.e. they "make" contact and therefor go off continually. Interesting to hear of a failure where it remains quiet :)
911 50th anniversary -
Post by sapphireblack » Wed Jan 11, 2012 3:14 pm
I realised post battery swap i'd had the bonnet only hooked shut when the car was on semi permanent trickle charging. I'll check it again specifically with a button depress, set the alarm and then release the button. If i end up deaf i'll blame..............someone :D
Post by sapphireblack » Wed Jan 11, 2012 3:32 pm
FWIW, the alarm works but the plunger is staying stuck down. A sharp upwards tug on it produces a loud noise :lol:
pvr
Post by pvr » Wed Jan 11, 2012 3:36 pm
And you are deaf now? :D
Post by X5Sport » Wed Jan 11, 2012 4:14 pm
Eh? What? Did you say summat? Nasty ringing in my ears...... :rofl:
Try a bit of silicone spray on the switch..
Post by sapphireblack » Wed Jan 11, 2012 5:59 pm
[quote=""X5Sport""]Eh? What? Did you say summat? Nasty ringing in my ears...... :rofl:
Try a bit of silicone spray on the switch..[/quote]
Tried that at the same time but it's like it's two stage notched. I'll need to enqure about replacing the switch :|
Post by X5Sport » Wed Jan 11, 2012 6:55 pm
Short of pumping it in and out a few (dozen) times to see if that makes it smooth out, I guess you're right. Having sold the car I can't look at mine for comparison, but I suppose it can't be taken to bits and cleaned can it?
storminmike
Post by storminmike » Wed Jan 11, 2012 7:53 pm
[quote=""sapphireblack""][quote=""X5Sport""]Eh? What? Did you say summat? Nasty ringing in my ears...... :rofl:
Tried that at the same time but it's like it's two stage notched. I'll need to enqure about replacing the switch :|[/quote]
£10.40 including VAT.......replaced mine when the alarm kept going off
Post by sapphireblack » Wed Jan 11, 2012 10:32 pm
Good to know, thanks.
millerman1ac
Post by millerman1ac » Sun Jan 15, 2012 1:52 am
[quote=""storminmike""][quote=""sapphireblack""]
£10.40 including VAT.......replaced mine when the alarm kept going off[/quote][/quote]
same easy job!! :thumbsup:
2004 4.4 Sport Black with Black
1998 Suzuki TL1000R, power commander, ART cans, K & N, TRE
x555
Post by x555 » Sun Jan 15, 2012 10:37 am
[quote=""sapphireblack""] A sharp upwards tug on it produces a loud noise :lol:[/quote]
Ooo eerr misus :lol:
[quote=""X5Sport""]Short of pumping it in and out a few (dozen) times to see if that makes it smooth out [quote]
come on now gents lets keep this forum clean now :rofl:
Rusty
Post by Rusty » Mon Jan 16, 2012 12:06 am
[quote=""x555""][quote=""sapphireblack""] A sharp upwards tug on it produces a loud noise :lol:[/quote]
[/quote][/quote]
Funny, only you picked up on that. Pmsl :thumbsup:
Runabout - E92 3 Series Coupe
Post by sapphireblack » Thu Jan 19, 2012 6:09 pm
All of £10.18p incl VAT and postal delivery. Five minutes under the bonnet and all is good. If only more BMW issues were as easily and cheaply resolved :(
