Key battery
garethdeb
Key battery
Post by garethdeb » Sun Mar 25, 2012 2:23 pm
Hi folks
My spare key works fine in the ignition but does nothing on the lock and unlock buttons so I'm banking on a dead battery. I've taken it for a drive with the spare but didn't charge so I did a search on here for how to replace it. Found the link to the yank site with a Pretty good description of how to change it but I just wondered if anyone on here had tried it themselves? At £150 for a new key I don't really want to be mashing it up!
Cheers all
Regards
Gareth
I am here: http://tapatalk.com/map.php?tibvyh
PhilT
Re: Key battery
Post by PhilT » Sun Mar 25, 2012 2:47 pm
Yeah, I replaced mine last year. Straight forward enough job. Once you've replaced it I'd suggest using that key for a while to charge it up, but take your spare with you until the new battery has got a good charge in it - just in case!
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
garethdeb
Key battery
Post by garethdeb » Sun Mar 25, 2012 6:00 pm
Thanks Phil. Where did u get the battery from? Did u follow the same guide I found?
Regards
Gareth
I am here: http://tapatalk.com/map.php?5qf3ju
PhilT
Re: Key battery
Post by PhilT » Mon Mar 26, 2012 3:35 pm
Will find the link and post you some more info when I get in tonight
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
PhilT
Re: Key battery
Post by PhilT » Mon Mar 26, 2012 8:33 pm
Here you go mate:
'How to' link
http://www.xoutpost.com/bmw-sav-forums/ ... y-fob.html
Ebay link for battery
http://www.ebay.co.uk/itm/VL2020-BMW-BA ... 4cfb910b97
When you slice the key open be careful not to let the stanley blade go too far in or you may catch the internals (as well as being careful not to slice your fingers etc. :cry: ). Also, the guide says to solder the battery back in place but mine seemed to be held quite firmly so I didn't bother with the solder and its been fine.
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
garethdeb
Key battery
Post by garethdeb » Sun Apr 01, 2012 2:40 pm
Ok, ordered the battery so I'll be giving it a go hopefully this week. Stupid question but will the new battery have charge in it to be able to program it or will I have to charge it for a few miles first?
Cheers guys
Gareth
I am here: http://tapatalk.com/map.php?ckdscu
Re: Key battery
Post by X5Sport » Sun Apr 01, 2012 3:21 pm
Most batteries come at least part charged, but you will in all likelihood need to give it a run to get more charge in there. It will depend upon how long the battery has been on the shelf, and it's type (NiMH, NiCd, Lion etc).
PhilT
Re: Key battery
Post by PhilT » Sun Apr 01, 2012 9:02 pm
I had to hold the key close to the rearview mirror to get it to program (which apparently is where the receiver is) so I'm guessing there wasn't that much charge in the new battery.
Also, I've been told that the battery charges up using some sort of proximity sensor, it doesn't actually have to be in the ignition, just near it (dunno how true this is but it came from a BMW mechanic).
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
Re: Key battery
Post by X5Sport » Sun Apr 01, 2012 9:07 pm
There's an inductive charging ring (coil of wire) around the ignition key slot which provides the necessary energy. Same system some electric toothbrushes now use.
Indeed there is anecdotal comment on the web that the Braun 'Sonicare' chargers could recharge a BMW key. Whether truth or myth I have no idea.
garethdeb
Key battery
Post by garethdeb » Tue Apr 03, 2012 6:04 pm
Don't think I'll try that one, guaranteed to fry the new battery knowing my luck!
Gareth
I am here: http://tapatalk.com/map.php?nnkg3q
