scanner 1.4 broke my clock
Hi folks,
well ok. it didn't break it i did.
i thought i'd try the GPS / RDS sync options on the IKE module. Things were working fine until the clocks went forward an hour and they didn't in the X5. Every time i manually move the hour forward it re-syncs and is an hour behind again.
I've tried unchecking the options using the scanner tool but it still keeps on syncing to something.
anyone had this before or know of a way to reset changes made using the scanner tool?
Pav
Pav
Re: scanner 1.4 broke my clock
I would just like to say
Did you press set then adjust time then press set again to confirm adjustment .
No scanner or tools required to do this , only a normal function of the car clock .
[quote=""amacman""]I would just like to say
No scanner or tools required to do this , only a normal function of the car clock .[/quote]
yep. the time does get set for a while, but then re-syncs somehow and returns to 1 hour before.
How long is 'a while'?
New one on me too. I didn't think the clock synced with anything, or is even connected to any other car function. As the man says, it's just a clock
Even the latest models with all their toys and DAB radios etc still don't sync automatically.
Do you have an Intravee? That is the only unit I know that controls the clock via GPS.
911 50th anniversary -
yep. i've got an Intravee with the extras.
I think it's happened because i ticked a checkbox on the IKE module called GPS-clock and unchecking hasn't undone this change.
i've got the Intravee user guide so i'll have a look if that might be the reason why.
Odd as since I scanned my car my iPhone name has changed on bluetooth only showing the first 3 letters and everytime i scan it turns on aux ventilation and sets the time to something non exist and like 33.76 hours
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
[quote=""gadgetJunky72""]yep. i've got an Intravee with the extras.
I think it's happened because i ticked a checkbox on the IKE module called GPS-clock and unchecking hasn't undone this change.[/quote]
Got to be worth a punt. GPS clocks run in UTC which makes sense given the hour shift you keep seeing.
[quote=""pvr""]Do you have an Intravee? That is the only unit I know that controls the clock via GPS.[/quote]
thanks pvr i think that fixed it.
[quote=""pgveeec""]scanner broke your clock?
i bought Newest S620 with my car in chinasinoy.com.
i felt this tool is great.[/quote]
I feel your a tool
I feel your a tool
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
