Name that part
dirtymonkey29
Name that part
Post by dirtymonkey29 » Mon Apr 16, 2012 5:12 pm
Any one know the name of the part pictured. Looking on realoem I think it's item no 6, guiding suspension link. Can't find anything on eurocarparts website. Wasn't much help when I rang either. Does it have a more common name?
X5Driver
Re: Name that part
Post by X5Driver » Mon Apr 16, 2012 7:09 pm
You probably did this but googled part no and most results say guide link
2005 X5 4.8is - 1995 Discovery 300tdi - 1970 Series IIa - 2004 CCM 644DS -2000 ZX12r
squeaky2
Re: Name that part
Post by squeaky2 » Mon Apr 16, 2012 7:29 pm
[quote=""dirtymonkey29""]Does it have a more common name?
Bob? :rofl: :exitright:
dirtymonkey29
Name that part
Post by dirtymonkey29 » Mon Apr 16, 2012 7:37 pm
Dave's more common lol.
shadrack
Re: Name that part
Post by shadrack » Mon Apr 16, 2012 7:43 pm
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
squeaky2
Re: Name that part
Post by squeaky2 » Mon Apr 16, 2012 8:58 pm
Pretty sure i had mine done when i had it and think this is what your after
http://www.allgermanparts.co.uk/ourshop ... 4-796.html
dirtymonkey29
Name that part
Post by dirtymonkey29 » Mon Apr 16, 2012 9:00 pm
Thats the same link I found too squeaky and there fairly local too. Did you change them yourself?
That's the one shadders... Will probably get it from squeakys link as there local and oem make too
shadrack
Re: Name that part
Post by shadrack » Mon Apr 16, 2012 9:13 pm
[quote=""dirtymonkey29""]Thats the same link I found too squeaky and there fairly local too. Did you change them yourself?
That's the one shadders... Will probably get it from squeakys link as there local and oem make too[/quote]
yeh fully agree to get local just thought that was the part you were after (name etc) :D
              2007 318d touring
              1964 vw beach buggy
squeaky2
Re: Name that part
Post by squeaky2 » Mon Apr 16, 2012 9:33 pm
[quote=""dirtymonkey29""]Thats the same link I found too squeaky and there fairly local too. Did you change them yourself?[/quote]
I cheated and got the guys at the garage next door to me to do them :). Didnt look too difficult a job for them though.....think it only took an hour or so
dirtymonkey29
Name that part
Post by dirtymonkey29 » Mon Apr 16, 2012 9:43 pm
Yeah, wheel off and a couple of bolts. Just wondering if hub needs jacking up to take some tension out. Will have to try and find a how to when I get home
squeaky2
Re: Name that part
Post by squeaky2 » Tue Apr 17, 2012 5:29 am
Having to go from memory and bearing in mind i didnt do it i dont actually remember the strut being under that much tension. It is literally just there as a stabilising bar to control the movement of the suspension
x555
Re: Name that part
Post by x555 » Tue Apr 17, 2012 7:40 am
This link may help fella viewtopic.php?f=22&t=2762 be carefull when undoing the nut at tge back. Make sure you lock the bokt and undo the nut as the bolt is elongated and only turns three quarters left or right as it controls the tracking.
dirtymonkey29
Re: Name that part
Post by dirtymonkey29 » Tue Apr 17, 2012 4:23 pm
Will probably get the part from allgermanparts then stick it in with local garage. Taking note of hub to wing measurement incase i need to re-tighten it under load if the garage doesnt. Although i will tell him too.
Did you get the tracking checked once you changed yours? or is that different on the rear?
