Another wheel snow tyre quandary question.....
Re: Another wheel snow tyre quandary question.....
What about 18's for the technical side but whack on 10 or 15mm spacers to fill the arches and look a bit better.....or is this just a NO!
X5 sd Msport 2008 - Black
996 C2S 911 - Black
Suzuki Jimny - Black (lane buster for the price to fill the X5!)
996 C2S 911 - Black
I run a 4.8iS on OEM 20s in summer and on 18s in winter (type 99). It doesn't look too weedy.
I wouldn't bother with 20 snow tyres - difficult to find staggered and expensive. I'd suggest something like the rims below -
http://www.tyremen.co.uk/product/11968/ ... 70%29.aspx
I have Vredestein Wintrac Extremes - superb - now in my fourth winter with them and go to the Alps up high 2/3 times a year.
Good luck
Good luck
4.8iS 2004 Le Mans Blue
Z1 1989 Top Red
Mitsubishi Outlander PHEV
Z1 1989 Top Red
I have been on and off this web site for the last few days also, and swithered over 18's versus 19's,
Finally pulled the trigger this afternoon on the 18's with Vredestein tyres,
Very similar to the std 18' SE wheels (style 209) from BMW, which would have cost circa £1500 alone without tyres,
Currently listed on alloywheelsdirect for £1252 (without tyres)
total price @ £1075 all in, tyres fitted, balanced, new bolts, including delivery to Scotland,
the way ebay was shaping up it was likley to cost same or more for used equivelants,
Not to mention the hassle of visiting the local tyre fitters to have old tyres off and new tyres on,
very good website, worth a look for anyone still looking,
CR55
[quote="gobiman"]
Good luck
CR55
[quote="gobiman"]
Good luck
CR55
CR55 - sorry, where did you end up buying? Alloy wheels direct or tyreman? Had a look on alloy and got a price of 1600 for same spec....that's when I found the tyres hiding in the 4x4 section and not the winter!
What do they look like, actually probably too soon if you did mail order. Pics would be good.
996 C2S 911 - Black
996 C2S 911 - Black
Tyremen,,,, Click on the web link earlier in the thread, same as wheels in the web page, similar to the OEM style 209,
Price was £1075, tyres mounted, balanced, new bolts and delivered,
This price was for 18" with vredestein winter tyres,,,
Good deal as far as I am concerned,,,
Should have them on Wed, if you want a few photos let me know,, but web page will show you also,
Cheers,
CR55
[quote="Flog"]
Cheers,
CR55
[quote="Flog"]
CR55
On the alloys from Tyremen, if you remove the Alutec centre caps and replace them with BMW ones (loads on ebay - OEM and cheap knock-offs), they will be virtually identical to the 209s and I suspect only trained forum members would tell them apart.
Z1 1989 Top Red
Z1 1989 Top Red
Well the deed is done...... Went ebay and got 19" replicas with 1000 mile Scorpion snow and ice tyres. If they are 1000 mile hen got a pretty good deal but we'll wait for final comments as they arrive tomorrow. ::)
Will report and get pics at weekend.
996 C2S 911 - Black
996 C2S 911 - Black
I have a set of the alutec design e 18" alloys. Unused. If someone wants to make a sensible offer
- Don Coffey
[quote="squeaky2"]
PM Sent.
Don
PM Sent.
Don
That is keen - getting wheels even before you have the car
911 50th anniversary -
Check the centre bores if the wheels are off an E70. E70 & E71 don't match. Can't remember which way around the issue is, but I think the X6 rear is smaller because of the clever rear diff. You might need spigot rings too....
- Don Coffey
Correct, the X6 has the smaller rear bore so spigot required.
Don
Don
- Don Coffey
[quote="pvr"]
In the final stages of negotiation. Fingers crossed will know soon. Look at winter wheels due to the area I live suffers with bad weather and no gritting or ploughing.
Don
Don
I have had two X 5s , a 2006 on 20 " wheels , and i went through the 2010 winter which was the worst for snow i can remember in 25 years without any problems. but your tyres need to have 5-6mm of tread,otherwise you will struggle even tho ' its a four wheel drive if tyres are worn out ! Run flats are crap anyway get rid !
Ive been through two winters on my newer X 5 2009 M sport D with 20 " standard wheels 315mm rears no probs but the snow was not so bad last year compared to 2010. I live on a hill but no probs getting home or about .
Ive worked in Germany for 15 years also on and off , the police wont let you on the Autobahn unless you have studs or chains on driven wheels , but i notice X 5s seem to get about . Im not saying there as good as a Landrover /RangeRover but X 5 cope ok . Why dont you buy some part worn skinneys 275mm /18" for winter £70 each on steel rims and then if you do slide into a curb its not so painful . The Germans dont use Alloys in the winter for that reason .
Past Bm 's M 6 ( 1986 ) ( all time favourite in 1980s so rare !), M3x 2 . 540 , 3 series loads ... X 5 x 3 . , 2006 X 5 M Sport, 2009 D M sport in white , Now 2011 X 5 4 D M Sport in white !
Ivory leather piped in black, Panoramic roof, camera x3 .
