Wanted. Boot lock
The foolish fellow
Wanted. Boot lock
Post by The foolish fellow » Mon Oct 15, 2012 12:29 am
I need a tailgate top lock. Anyone sellin one for an e53.
The foolish fellow
Wanted. Boot lock
Post by The foolish fellow » Sat Nov 10, 2012 1:02 pm
Bump
Sanj
Re: Wanted. Boot lock
Post by Sanj » Sat Nov 10, 2012 1:34 pm
Tried eBay? Any there?
Raj
Post by Raj » Sat Nov 10, 2012 3:14 pm
[quote="Sanj"]
Yes.
Was that not directed at me???  :-[ :))
The foolish fellow
Wanted. Boot lock
Post by The foolish fellow » Fri Dec 14, 2012 12:50 am
No actually , not. The 04' onwards is different from previous ones.
JPR
Post by JPR » Fri Dec 14, 2012 12:14 pm
Hi,
I don't know if this helps, but I had a problem with my boot lock and thought that it would need replacing. However, when I took it apart I found that it was only the spring that had broken. Once this was repaired it was fine again.
The foolish fellow
Wanted. Boot lock
Post by The foolish fellow » Mon Dec 17, 2012 10:35 pm
How did you get it apart . What year is yours ?
JPR
Post by JPR » Tue Dec 18, 2012 12:08 am
Hi,
2003 pre-facelift.
If I remember correctly the mechanism just clips together.
Getting to it is more awkward. The interior trim around the window is fiddly and you have to remove the rear wiper assembly to get access to the latch mechanism. I also attached a length of wire to the emergency boot release so that I could feed it back into position after the repair.
The foolish fellow
Wanted. Boot lock
Post by The foolish fellow » Tue Dec 18, 2012 12:50 am
Lock different. 04 is a bit heavier and more complicated. Easy enough to remove though .
JPR
Post by JPR » Tue Dec 18, 2012 1:06 am
OK. Best of luck with your search.
The foolish fellow
Post by The foolish fellow » Wed Mar 27, 2013 12:40 am
Still lookin , but as you may imagine i am no longer in any hurry as I can close the tailgate by pressing the key or the bootlock switch on the tailgate causing the solenoid to pull the boot closed.
