cant get breaks to work on rear of x5
x5 failed mot mon as need new break lines on rear all done but got no breaks on rear, now they have been bled and all air locks taken out by garage but still no breaks can anyone help asap someone said its because a abs and dsc
- wilkoturbo
Re: cant get breaks to work on rear of x5
no not seazed they were working great before, it need the brake lines change as rusted,now not back brakes not working,and garage dont know what else to do as they have bled the brakes and took or airlocks out still no pedal front ok.
someone told garage its something to do with pump as x5 as abs and dsc, i dont think this is the case please as anyone had this problem after changing brake lines
If the garage let air get into the ABS pump then you will need a BMW specialist to bleed the system through properly using their fancy machine.
- Steamyrotter
If they did that then they should sort it FOC
Please note...
Please note...
The abs valve needs to be cycled and opened using the correct software as this has closed off the feed to the rear lines. No matter what you do the rears won't bleed until the correct procedure is followed to open the valve again.
Thanks for that mate looks like i need the bmw people then cost
I have just spoken to someone at bmw and they say you dont need BMW specialist to bleed the system through properly using their fancy machine to bleed the rear brakes or plug it in, just bleed them they say,please some help it costing loads.
[quote="ozzyhufc"]
That's interesting as when the calipers were re-done middle of last year with the rest if my build thread we went through a fair bit of fluid to try and bleed them and nothing. In the end Jason had to sort.
Ask Jason @ BW off here but pretty sure you'll not be able to just bleed them.
Cheers Raj , the garage tell me they are have someone coming round to garage at luchtime with bosh kts kit to open valve to rear brakes and will need alot of dot 4 to bleed, so i dont know why bmw said u can just bleed them, i hope it is sorted today and they dont charge me loads as it been in garage for 3 days now, but at they end of day they should only charge me for new brake pipes as it was there fault they got air into it.
[quote="ozzyhufc"]
Agreed. You've paid them to change the lines. If they have introduced air into the system and have to get an outside source to sort it well that's their own problem. They agreed to take the job on and should have known potential issues that could arise.
Don't let them charge you for the extra costs.
Removed poll from this post.
To the OP - good luck and as other have said, pay only for the work asked for and not for problems introduced due to the work.
911 50th anniversary -
The BMW TIS instruction for bleeding brakes with cars equipped with DSC (your is) notes that the BMW Diagnosis and Info System (DIS system) must be connected in order to run through the bleeding correctly. If they didn't follow this then they messed up, and should fix at their expense as suggested above.
Cheers everyone for the replys i will let you know, i hope to get x5 back today i miss it, and i will let you know how much they charge me for work.
