LED Tail Lights installed but have some issues
Sanj
Re: LED Tail Lights installed but have some issues
Post by Sanj » Sun Dec 16, 2012 5:48 pm
[quote="X5Sport"]that's a pic of a capacitor.....not a resistor.  Good suppressor though.
R
That's one thing I know nothing about buddy... ???
But it does the job.  ;D
mikem
Post by mikem » Sun Dec 16, 2012 8:05 pm
Why not use the scanner and turn off the hot and cold bulb tests for them instead of fitting resistors ?
Sanj
Post by Sanj » Sun Dec 16, 2012 8:14 pm
[quote="mikem"]
These help stop the bulbs flickering too.
But yes an idea - just that you lose a useful function of knowing when a bulb is out.
mikem
Post by mikem » Sun Dec 16, 2012 9:47 pm
Sanj, is the flickering not a result of the bulb test ? My led angel eyes used to flicker untill I turned the lamp test off. I believe the test sends a small current through which isn't enough to light up the OEM bulbs but is enough to light the LEDs, hence the flicker.
Sanj
Post by Sanj » Sun Dec 16, 2012 9:51 pm
No, this is the stupidly rapid flickering you get.
The start-up bulb test is just for the car to work out if 'all systems are go'.
