Connection Points for the 40 Pin & Radio Convertion Extension Lead
shy7g
Post by shy7g » Sat Feb 02, 2013 6:27 pm
Hi in the middle of running the  40 Pin & Radio Convertion Extension Lead from the new head unit to the rear of the car (X5 E53 4.6is model) inside more or less totally stripped out down the whole of the passengers side. Does anyone know where in the rear of the vehicle the 40-pin conncetions have to be made?
here's a photo of the type connection block ( there's two in total that have to be connected
thanks
Sanj
Re: Connection Points for the 40 Pin & Radio Convertion Extension Lead
Post by Sanj » Sat Feb 02, 2013 8:15 pm
Into the quadlock - that is connected to the RCM (Radio Control Module) buried under the spare/compressor/plastic surround next to the battery.
Circled below:
shy7g
Post by shy7g » Sat Feb 02, 2013 8:49 pm
shit that mean's I'll have to lift my LPG tank :wall:
Is the radio antenna/ aerial connection plug/point down there as well?
Is it OK to fit the GPS antenna behind the panelling as it has a magnetic base?
thanks
Sanj
Post by Sanj » Sat Feb 02, 2013 8:57 pm
I'm afraid - yes, yes and yes.
And you're welcome.
Ubatoid
Post by Ubatoid » Sun Feb 03, 2013 8:59 am
If you have OEM sat nav, I would suggest connecting the GPS aerial to the original one in the spoiler. Putting behind the dash does work but is far from ideal and you will have signal issues at times.
2002 4.4 cooking on gas
shy7g
Post by shy7g » Sun Feb 03, 2013 2:13 pm
[quote="Ubatoid"]
I have the pre-facelift model is the GPS aerial in the spoiler on this model also?
Also is the connection point of the OEM sat nav, is it on the back of the original radio unit or in the rear well?
