DRL Coding
Ubatoid
DRL Coding
Post by Ubatoid » Sun Feb 03, 2013 4:14 pm
First off, thanks to Kkodal78 for allowing me to purchase his redundant Depo lights inc 55w HIDs.
Next thing is is there a way to code the rings to come on as daylight running lights ?
I had a quick look with the scanner, and was able to try EU, US and Denmark as options, but these just put the dipped lights on aswell as the halos. I know it can be done with a bit of fancy wiring and a relay but I would rather do it the "proper way" if possible.
Any hoo, here is a piccy of them fitted - Sorry KKodal, didnt like the mesh wrap.....
No comments on the state of the wheels please - they are on my list of mods - well thats my excuse anyway...
2002 4.4 cooking on gas
kkodal78
Re: DRL Coding
Post by kkodal78 » Sun Feb 03, 2013 4:25 pm
Looking good.
Re: DRL Coding
Post by Horizon » Sun Feb 03, 2013 5:11 pm
I tried all the options of DRL's on the scanner, as I wanted the marker LEDs as well.
I had the dipped beam on with the markers ( same as you get on the normal headlight setting, also had the front indicator lights on as side markers, got sick of people pointing it out as though there was a fault, so reverted back to standard. Us setting uses low power high beam, eu uses dipped beam. I've got LED markers and 55w HIDS.
shadrack
Re: DRL Coding
Post by shadrack » Sun Feb 03, 2013 5:51 pm
it wouldnt be that hard to do the relay route, just get sanj on the job!
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
jaynana
Re: DRL Coding
Post by jaynana » Sun Feb 03, 2013 11:25 pm
i've tried all combinations and permutations with the scanner - cannot switch on the halos with the scanner.
i suppose because on the E53 they wouldn't pass as DLRs.. where they're needed as DLRs.
don't know about thee mystic world of ncs though - worth checking the bmwcoders, bmwcoding forums..
mikem
Re: DRL Coding
Post by mikem » Mon Feb 04, 2013 3:27 pm
Intravee will do it on facelifted E53.
Rusty
Re: DRL Coding
Post by Rusty » Mon Feb 04, 2013 6:47 pm
[quote="mikem"]
Ooh ooh, tell me more......
Runabout - E92 3 Series Coupe
psychosis
Re: DRL Coding
Post by psychosis » Mon Feb 04, 2013 9:28 pm
In the control menu of the intravee you have options for min number of indicator flashes and using AE as DLR.
2004 E53 X5 4.4i Sport
Rusty
Re: DRL Coding
Post by Rusty » Mon Feb 04, 2013 11:02 pm
Cool - I'll have a look for that tomorrow.
Steamyrotter
Re: DRL Coding
Post by Steamyrotter » Tue Feb 05, 2013 1:11 pm
All BMW's with AE are already fitted & coded for AE as DRL.
You just need to turn the little rotary control on the RHS of the steering column one click to the right of centre.... >:D >:D >:D
Please note...
jaynana
Re: DRL Coding
Post by jaynana » Tue Feb 05, 2013 2:07 pm
[quote="Steamyrotter"]
what?? no way! by default that turns on the dipped headlights when the car is on. certainly doesn't run the AEs as DLRs by default.
you can of course change the DLR config from the dipped beam to the high beam or the side lights. but u can't change it to AEs (with the scanner).
i will  try out waht is said below about the intravee.. hopefully later today.
B5tew
Re: DRL Coding
Post by B5tew » Tue Feb 05, 2013 4:03 pm
[quote="psychosis"]
[/quote]I just had a look at mine and I have not got the option on my Intravee  :(
----------------------Sanj Help please --------------------------------------
2015 Space grey 30d F15
Re: DRL Coding
Post by X5Sport » Tue Feb 05, 2013 5:10 pm
On my old E53 the AE's only were on the first right notch and dipped headkights on the second.  E70 & E71 made from 2010 now have front and rear DRL function controlled from the iDrive (it's a factory added option for UK Spec at that time).  The Mini also has the function but that turns the dipped HIDs on instead of the sidelights.
mikem
Re: DRL Coding
Post by mikem » Tue Feb 05, 2013 6:44 pm
If you've not got the option on your IV, you need to download the latest firmware or accept the disclaimer if you e already got it.
jaynana
Re: DRL Coding
Post by jaynana » Tue Feb 05, 2013 7:19 pm
here's what i get. older sw version?
richard & steamyrotter, i see what you mean now - that's no DLR that's manually switchin on AEs everytime u want em.  >:D engineers!!
u see - us non engineers like  them to come on automatically and not having to switch them on manually!  8)
